Question about Canon PIXMA MP830 All-In-One InkJet Printer
ADF can't print
When I first bought my Cannon mp830, I was able to stack and print from my ADF, no problems. Now it will not feed even a single sheet of paper. Can anyone help?
  • 1 more comment
  • Anonymous Mar 25, 2008
    Paper starts to feed through and then runs into a snag of some sort, crumples up and jams. What can I do to fix this problem?
  • Anonymous Mar 26, 2008
    Paper starts to feed and then gets jammed. I've pulled it out every time it jams. I look for tiny bits of paper that might be jamming but have found none.
  • Anonymous Dec 08, 2008
    I have this same problem. it started once the computer was purchased.
  • 28 Answers
Maybe your ink is already empty... try to change ur ink cartridge... but first try to check out your printer settings at your computer... there might be problems there that's why it won't work...
Posted on Feb 28, 2008
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Dec 08, 2014 | Copystar CS-2550 All-In-One Printer
Document in ADF error, however there are no
I'm having the very same problem. No paper was ever stuck and the first time I tried to scan a document by laying it on the glass, not even through the feeder and it did this, and just like with you now it won't even print. Apparently this happens a Lot. I sure wish I would have seen these issues before I bought it! I wish I could help you out, but at least you know you're not alone.
May 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My Lexmark X75 comes on and seems ready for printing, but the paper will not feed -- either a single sheet or a small stack of sheets.It won't feed even when I press the paper feed button.
Gave up on you folks because I do not use credit cards and that seems to be required before I'm allowed to ask for assistance.
Thank you, anyway.
gramalee
Jan 22, 2010 | Lexmark X75 All-In-One InkJet Printer
I have a problem with my MP830 it is not scanning.
- Confirm the connection
- between the ADF motor and the ADF PWB, and
- between the ADF PWB and the logic board.
- Replace the
- document feed unit, or
- logic board.
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Feed problems cannon pixma MP220
I would remove and reinstall the driver to see if that will correct the single copy problem.
On paper: low cost paper generally has a high wood fiber content making the surface rougher than that of better paper stock and more likely to 'stick' together. With any kind of paper, it is useful to fan the stack before placing it into the feed tray or cassette. Sometimes the edges are not sheered cleanly which can also cause them to tend to stay together. Fanning helps overcome this too.
Jan 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
SCX-4216 "No Paper" message
I've had this happen to my scx4521f a few times. I think I had too much paper in it. Or maybe it was poorly loaded paper. Take the stack of paper out and turn it around so you have no dings or dents on the inward facing side. You need to make sure that the paper is stacked evenly. Good luck. And now I will post my problem.
Apr 09, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
Printing and faxing more than one page at a time
Hi This is a common problem, not only with your printer, but most at some time or other. In part it seems you get what you pay for, in that if you buy premium paper (business grade 40 mil), you normally have less problems. The paper is drawn into the printer by a rubber or compacted foam roller, and sometimes the paper sheets will sick to each other, and more than one will be drawn in. The best thing to do if you are using less expensive paper, or even the expensive stuff, is to "fan" the stack of paper several times with your thumb, at the end that will face the rollers, and also don't let the stack get down to only 3 or 4 sheets, as the problem is worse near the bottom of the stack. Hope this helps. Good Luck!
Nov 30, 2006 | HP OfficeJet 6110xi All-In-One Thermal...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
225 people viewed this question
old marine
old marine
