Question about Honeywell Programmable Thermostat Heater
Honeywell Thermastat rth2308
I have been hearing my gas shutting off and quit a bit latley/ it is not something that is happening all the time but when it comes 0n i do notice that it is only a matter of seconds before is comes back on. b ut won't stay on all the time as well.
got any Ideas? plus I might add that I have changed the thermostat on the wall and it seems to be workiing ok, I even put it on the manual mode instead of the programable mode got any Ideas as to what I can do ?
a very greatful questionor. Tina
    Problem Solver:
  • 6 Answers
Yes you can fix it in 10 min.
You wasted your money on thermostat. Problem is your flame sensor. your Furnace has a safety. When it dosen't sense the flame because of crotion build on the sensor it shuts itself off in 3 seconds. flame sensor is on the right or left side infront of the burner. it is about 2.5 to 3 inches long and about the size of Q tip. it is mounted with one or two #6 hex or sloted head screw. You may or may not have to take it out depends on what is in the way and how big is your hand ! any way you will have to run to the hardware store and buy a sheet of very fine grid SAND PAPER. Clean it very good with it. If you have Glow igniter that ignite the furnace. DO NOT TOUCH THAT. It looks like round spiral or W shape. you can't miss it thats the one that starts the fire. DO NOT TOUCH THAT. but you can clean the sensor without messing with the Igniter. you can only Clean the sensor 3 to 5 time then you will have to buy a new one. you can click on this link to know what sensor looks like.
http://images.google.com/imgres?imgurl=http://www.pse-usa.com/pics/sensor-2.jpg&imgrefurl=http://www.pse-usa.com/sensors.htm&h=300&w=400&sz=13&hl=en&start=1&tbnid=bWJA_1jFxpGyyM:&tbnh=93&tbnw=124&prev=/images%3Fq%3Dflame%2Bsensor%26gbv%3D2%26hl%3Den%26sa%3DG
Please let me know if that works for you.
look at the igniter link you don't want to mess with this part.
http://images.google.com/imgres?imgurl=http://midwestapplianceparts.com/images/41-407-IGNITER.jpg&imgrefurl=http://midwestapplianceparts.com/heating-air-conditioning-122/&h=557&w=500&sz=31&hl=en&start=16&tbnid=la_Q0h6RdK4uQM:&tbnh=133&tbnw=119&prev=/images%3Fq%3D%2Bigniter%26gbv%3D2%26hl%3Den%26sa%3DG
Good Luck
Posted on Mar 07, 2008
I need a manual for Honeywell RTH2308
Hi
Please open this link
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf
Thank You
Dec 26, 2017 | Honeywell Heating & Cooling
Pilot lights up but would not fire up into heating, I have brivis buffalo 85
This is the proper cycle of a furnace and what should happen.
Inducer motor kicks on, it runs for a little bit, about 3-5 seconds, then you should see a bright yellow glow, this is the igniter, shortly after, you should hear a click and the gas should start to flow, almost immediately it turns to a blue flame. Then your igniter should turn off and the blower motor start up.
If the pilot turns on and the gas ignites, then shortly after the unit shuts off, chances are this is your blower motor. It is not starting up, then the heat limit is reached in your unit and the safety shuts it off.
Mar 02, 2011 | Honeywell Programmable Thermostat Heater
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Does this thermostat have a delayed start setting?
You will have to have the installer manual and go into the con fig settings to change Honeywell.com
Jun 16, 2009 | Honeywell Electronic Programmable...
Short burn cycles
if thats a new themostst it sounds like you didnt set the cycle dip switches correctly,the type of heat you have is unknown to the thermostat so you have to tell it or it may short cycle or overheat
May 02, 2009 | Honeywell Heating & Cooling
Honeywell heating system
go to the main power box and find the either breaker or fuse that runs the system and turn it off
Dec 25, 2008 | Honeywell Programmable Thermostat Heater
Furnace will not shut off
something is wrong with the thermostat.  replace it first, that would be the cheapest alternative
Nov 23, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
359 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
