Question about Dishwashers
Dishwasher runs, but doesn't fill with water to wash
  • ed35401 Feb 25, 2008
    Its still not filling. I am seeing a little water leakage from the jets. You think the jets could be clogged?
    President:
  • 2,651 Answers
Reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Posted on Feb 24, 2008
  • Ron Coons
    Ron Coons Feb 25, 2008
    there would still be water inside unit even if jet s are clogged, sounds like water valve issue, can you remove leads to water valve and plug your meter leads into the wires from from valve sett to 110 volts, reset d/w for normal aoperation and wait a few min to read 110v ac. if it does you have a bad water valve, if not we gotta figure whre you lose the power
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Tip
How to repair or fix a Dishwasher if it doesn't wash well
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
on Sep 03, 2010 | Dishwashers
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
Fills with water and drains will not run to wash dishes
The main water pump is not working. A repair will be pricey. it may be best to get a new dishwasher
Apr 21, 2009 | Dishwashers
White film on glasses after a run.
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
2) Adjust the detergent amount.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
Apr 18, 2009 | Thermador DWU244 Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Dishwashers Logo
164 people viewed this question
Top Dishwashers Experts
