Question about Metrik Amplifiers MAP-602 Car Audio Amplifier
Goes into protect mode
This happens when it is turned up too loud....i have two 10in jl audio subs (10W1V2-4 model) bridged n when i turn it up or when it hits a hard bass note it will turn off n i have to take the cd out n put it back in to make the light turn green again...why might it do this?
  • jaspersaing5 Nov 17, 2008
    i have two 12"s rockford fostage with a 1000 watt 2 channel amplifier and everytime i turn it up it will go into protect mode even if i would use only one subwoofer
  • 25 Answers
Your amplifier is trying to draw too much current. Your battery doesnt have enough power to run the subwoofers. My solution to the problem would be buying a power cap with equal or more power capasity to your current amplifier. The power cap stores a high amount of current so that when your subwoofers hit those low notes that draw a lot of current, instead of taking it directly from your battery, it will use the stored current from the powercap and wont go into protect mode. Also make sure that your connections on the back of the subwoofer arent touching. If you are hitting hard bass notes and the speaker (+) and (-) wires touch, it will short out and go into protect mode. But I dont think this is what your problem is. I am 99% sure if you go with the powercap, it will solve your problem.
Posted on Feb 24, 2008
  • Brandon Perkins
    Brandon Perkins Feb 24, 2008
    also, make sure that the power cap is charged before you install it. Find a 12v light bulb and use that to charge your cap. Connect the neg to the neg on cap, connect one end of 12v light bulb to the battery, the other to the cap's pos. Now wait few seconds and the light will go out. The cap should be fully charged. If you dont charge it, then it will just pass current as if there was no power cap to begin with.
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your remedy...gd luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
How do you bridge the jl audio 450/4
Nice amplifier. However it is best suited for speakers and not for sub woofers. Connect the plus (+) from speaker output 1 and the minus (-) from speaker output 2. Connect the plus (+) from speaker output 3 and the minus (-) from speaker output 4. Now the amplifier is in bridge mode, which will give you 300 WATT RMS at 4 OHM load. If you are bridging the amplifier to run sub woofers then do not forget to set the X- Over to LPF on the channels that you are planning to bridge. Whatever you do, make sure that the load you are asking the amplifier to play is no lower than 4 OHM. Playing this amplifier in bridged mode lower than 4 OHM is a recipe for trouble.
dreamsystems
Feb 12, 2011 | Jl Audio 450/4 Car Audio Amplifier
Amp goes into protection mode when i turn up volume
Sounds like you are running your subs at to low of ohm. Amps are rated differently on the levels of ohms or resistance that they can get to. If you have a dual 4ohm sub and run it in pairrell it will drop to 2ohm and if you run the same sub in series it will be 8ohm. Your amp will go into protection if the ohm is to low.
-david
Nov 07, 2010 | Jl Audio 12W6 Car Subwoofer
I have a 1200 watt G-Max sub amplifier and it just went into protect mode
Turn down the volume or power settings on it since its pulling too much power and shutting off for a few sconds to keep from blowing. Depending on the amp and speakers your using dont bridge the channels. If it won't come out of protect mode then unhook everything and just hook power, ground, and remote and wee what happens. If it comes on again and stays on then amp is blown.
Aug 11, 2010 | Jl Audio Car Audio & Video
I have a JL total mobile audio T500.1 mono amp and it was playing then all the sudden it stopped and the power light which is usually green is now red and stays red and no sound comes from the subs any...
This happens when the amp goes into protection mode. 90% of the time, it means there is a short or has another issue inside the unit and has to be fixed or replaced. Hope this helps and good luck!
Jul 09, 2010 | Jl Audio Car Audio & Video
I hooked up my jl audio 500/1 and it turns on but there is no response from the subs.
-Did you verify that you have an input signal?
-Is the amp going into protection?
-If they are bridged mono, are they bridged across the appropriate terminals?
-If there is a subwoofer line out on your head unit is it muted or turned off?
Jan 04, 2010 | Jl Audio 500/1 Car Audio Amplifier
How can i make my jl audio 12w3-d6 into a 4 ohms
it depends if the amp is mono or stereo and if it is bridged. if it is bridged the amp cant handle the speaker the best way is to lower the level on the amp or connect it to only one channel. also you might want to check your ground cable use a thick one and make sure its making good contact with the chassis. this happened to me. luck
Sep 12, 2009 | Jl Audio 12W3 Car Subwoofer
Low ohm light stays on my jl 1000/1
you have your amp wired at too low of an ohm load for the amplifier. This is why it is doing this. Jl amps are awesome and pretty much make everything idiot proof. Not calling you an idiot but go online and search for that model on JL.com then look on either the box your subwoofers came in or on the back of your subwoofers. Find out which ohm load they are and how many voice coils. Next go to www.the12volt.com and find the subwoofer wiring diagrams close to the top of the page. Then enter in your information on your sub's impedence and how many you have then it will give you the wiring options that you have and it will probly tell you you are wired at like a .5 ohm load. And let me guess you turn it up too long or too loud and your amp gets hot and it goes into protection.
Jun 09, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Sub makes loud noise when car is shut off
Does it make noise if the RCAs are unplugged? If not, the RCA shield on your head unit may be burned open.
If the amplifier is set to signal sense, it will take longer for the power light to go off.
Nov 13, 2007 | Jl Audio 250/1 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Car Audio & Video Logo
211 people viewed this question
Top Metrik Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Metrik Car Audio and Video Expert? Answer questions, earn points and help others
