LG GL6000ER Air Conditioner
Problem for LG GL6000ER Air Conditioner
Ac unit
By nyc fabian on Feb 24, 2008
compressor goes off on high pressure , replace condenser motor still same problem
Same Problem
Mar 16, 2008
-   if out fan motor running good condition then no need to replace fan motor.
1.wash condensar coil properly with casti soda.
2if condensar coil is damage then change condensar coil with new one.-   sur007
Best Solution
posted on Mar 15, 2008
Very Helpful)
sur007
Rank: Guru
Rating: 88%, 72 votes
wash condensar coil with castic soda then use water n surf clean the condensar properly,check gas back pressure n discharge pressure.suction pressure must be 65 psi
Comments:
Mar 16, 2008
- if condensar fan motor running good condition then no need change fan motor,
1.wash condensar coil with castic soda
2.check fings of condensar coil
3.if fings damage then change condensar coil.
Mar 17, 2008
- 1.check condensar coil
2.check refrigerant pressure
3.if problem comes again change condensar coil.
4 if ambient temperature more then discharge pressure then compressure do not work.
5.if direct sun light falls on condensar.then change the site of out door unit.
Was this helpful?
Yes
No
Solution #2
posted on Feb 24, 2008
Not Rated)
fixr1st
Rank: Wiz
Rating: 84%, 67 votes
I would start by washing the condenser coil thuroughly, then if it continues check refrigerant charge.
Was this helpful?
Yes
No
Solution #3
Not Rated)
bobotfel
Rank: Guru
Rating: 87%, 288 votes
Reprocess the system.
Was this helpful?
Yes
No
Popular Solutions for LG GL6000ER Air Conditioner
Questions and Unsolved Problems for LG GL6000ER Air Conditioner
Do you recommend LG GL6000ER Air Conditioner?
Answer
Answer
i have a pioneer air con ducted model no:ps11. i neen the cap sizes as the old ones dont have a... (More)
Answer
Hi, My Fujitsu airconditioner turns on by remote but it doesnt blow cold air.Its a dual hook up... (More)
Answer
how do i turn down/disconnect the beep sounds when buttons are pushed?
Answer
samsung ac unit lp420kpa condensor fan is in good condition. when the unit is put on heating the... (More)
Answer
I have no outside window sill I can attach the support but have place for the leveling bolt. Do I... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , IL
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
