Sony tv not turning on
Sony rear view projection tv power to house went off 3 times in one day tv not tuning on tried to reset wih remote all ok then after a few hours tv not coming on red standby light flashes 10 times at intervals.,
  • mirag29 Feb 24, 2008
    WEGA TV KPFW46M31 thanks
    Genius:
  • 1,175 Answers
I would need the model number to look service codes
Posted on Feb 24, 2008
  • Scott Frye
    Scott Frye Feb 24, 2008
    try this site :
    http://myweb.accessus.net/~090/sonyadj.h...
    It has Wega service mode info
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Aug 21, 2011 | Mitsubishi VS-50609 50" Rear Projection...
I have a sony grand wega 65" and i am trying to figure what is wrong it has a light blue X in the middle of the screen and it does not come off
Hello
Your Sony tv is locked I thinks. Try to reset your TV by the flollowing method.
Unplug your TV from AC mains wall socket, and let it be in that state for about 10 minutes or so. Plug it again, and switch on the TV.
While holding down the "Reset"button on the remote control, press "Power" button on the TV. [The TV will turn itsef off, the back on again]. Release the reset button. [NB: You must hold down the Reset button on the remote control until the proess is over.]
OK.
Feb 26, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
TV WONT START UP - RED LIGHT COMES ON AND THERE IS A CLICKING NOISE AS IF IT IS TRYING TO RE START - IS IT THE LAMP UNIT OR STARTER?
if the lamp has gone the bottom light will flash if the top flashes there a problem with the tv there is reset you can do
  • Point the Sony remote control at the TV and press and hold the "Up" arrow button.
  • 3
    Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on.
  • 4
    Select "OK" when shown the factor settings and the television has completed its TV reset
  • Read more: How to Completely Reset a Sony TV with a Blinking LED ' eHow.co.uk http://www.ehow.co.uk/how_6011902_completely-sony-tv-blinking-led.html#ixzz17Eijjdrn good luck regards shaun
    Dec 05, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
    Changed lamp and TV won't turn on, power light flashes 3 times
    Red light blinking 3 times shows problem with lamp cover.
    Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
    Thanks.
    Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
    Turn off after a few hours
    If the TV turn itself off then perform the following steps:
    (i) Check if the Sleep timer is activated.
    (ii) Check if the Parental Guide prohibits viewing during that time and/or limits amount of viewing time per day.
    (iii) Check the batteries on your remote, low battery power may cause random signals from the remote.
    (iv) Disconnect all the cables from the TV then reconnect them after a few hours.
    (v) Ensure the power cord from the TV is directly connected to a functional wall outlet.
    (vi) You may also try resetting the TV to the original factory settings by pressing the Reset button on the remote control supplied with the TV when in Menu.
    The following is the information indicated by the blinking patter of the standby/timer lamp on the TV:
    2 times : Power does not come on.
    Load on power line shorted.
    3 times : The TV has entered standby mode.
    4 times : Has entered standby state after
    horizontal raster.
    Vertical deflection pulse is
    stopped.
    Power line is shorted, or
    power supply is stopped.
    5 times: No raster is generated.
    CRT Cathode current detection
    reference pulse output is small.
    6 times: No picture
    9 times : No sound
    Furthermore, the TV is equipped with a self-diagnosis function that you can use to determine whether the issue is related to any hardware malfunctioning. Perform the step given below to run self diagnosis:
    Quickly press the remote command button in the following order from the standby state.
    Display -------> Channel 5 ---------> Volume -(minus) --------> Power ON.
    If the Self Diagnosis display numeral "1" for any parameters then a fault has been detected and service will be required.
    wish u good luck!!!!!!!!!!
    Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
    Need to reset Mistubishi 48 rear projection tv.
    Follow the steps below for the initial set-up:
    1. Select the "MENU" display by pressing the "MENU" button once.
    2. Press the number buttons "2", "2", "7", "0" in sequence to select the "OPTION MENU" display.
    3. Press the "ADJUST" button to select "INITIAL."
    4. Press "ENTER."
    NOTE: At this time channel 3 is automatically selected.
    This will reset the the tv ....
    Feb 18, 2009 | Mitsubishi WS-48613 48" Rear Projection...
    Sony KP-53N74 Rear Projection TV won't power up
    how was the picture before ? nice and bright if was ok it may worth fixing probable just power board get the hit ..
    May 16, 2007 | Sony KP-53S35 53" Rear Projection...
    Will not turn on
    how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
    Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
    Televison & Video Logo
    258 people viewed this question
    Top Televison & Video Experts
