Question about Sony STR-DE345 Receiver
Protect Flashing Sometimes
HI I HAVE PROBLEM WITH MY DE 345 THE PROTECT KEEPS FLASHING BUT IT ONLY HAPPENS WITHIN CERTAIN RANGES. lIKE WEHN IM WATCHING TV IT CAN NOT BE WITHIN THE 7-10 SOUND LEVEL RANGE BUT IT CAN BE ABOVE IT OR BELOW IT. THE ONLY PROBLEM IS BELOW 7 REALLY DOES NOTHING BUT PUTTING IT AT LIKE ABOVE 10 CAN MAKE IT HARD TO HAVE CONVERSATIONS WHILE LIKE FOOTBALL IS ON. WHAT CAN I DONT TO FIX SO IT WORKS IN THE 7-10 RANGE
  • uvaljb May 21, 2008
    Protect flashes - and the amp is not working. happens alot.
    What should I do with it ?
    Genius:
  • 1,175 Answers
Dust the cabinet out with one of those cans of "dust off" compressed gas and make sure you have PLENTY of ventilation around the amp.
Posted on Feb 24, 2008
Kenwood kdc-mp345u keeps flashing protect, and i've disconnected the speakers and unplugged the radio for about 30 min, plugged radio back in still flashing protect
Chances are pretty good either the output ic or the volume control ic inside of the radio are bad. Both require the ability to use a soldering iron to replace.
Aug 03, 2011 | Car Audio & Video
The red light keeps flashing
Im afraid the set is probably in an over current protection mode wherebye it shuts down to protect itself as one aaea of the tv is drawing excess current, the pattern of flashes will have a code which would guide a techie to problem area, im afraid you will need an engineer visit,sorry George
Nov 03, 2010 | Samsung LN40A450 LCD TV
My car radio keeps flashing protect do i need a code
don't know what kind of radio you have, but usually if a radio is flashing protect it is because you have a short in the wiring, a bad speaker or a bad output ic.
Jun 18, 2010 | Car Audio & Video
Protect led flashing with hit of bass
Try a bigger amp. This one wants to be turned down. But seriously the protect can act like sort of a clipping device when the unit is trying to amplify out of a certain range. The transistors may be getting weak and need to be replaced. That said I would move this amp to the midrange or the highs and get a little bigger amp for you low low's. Hope that helps.
May 08, 2010 | Blaupunkt GTA 260 2 Channel Amplifier 400...
Stand by light just keeps on flashing red and i cant press any otehr buttons it just keeps flashing red
something inside the unit has caused it to go on protect mode it sounds. check the v supply from the fan as well as the audio output ic and main pc board.
Jul 05, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Flashing protect
the protector comes on to keep the amp from further damaging itself or the speakers. The buzz you heard was probably 60HZ line buzz from the main DC supply conducting full current through one of your speakers through a damaged amplifier transistor. Your stereo will need professional repair. The protect circuit basically opens the speaker relay (and sometimes shuts down the unit) to prevent this DC voltage and current from getting to your speakers until the problem is corrected.
Jun 17, 2009 | Onkyo TX-SV727 Receiver
Protect flashing
es posible que un canal se ha dañado por lo que primero daño el fusible con la sobrecarga y posteriormente se daño el canal. es necesario se revisen las polarizaciones de los transistores para determinar el canal dañado,es seguro que el daño se encuentra en uno de los frontales.
Mar 21, 2009 | Sony STR-DE345 Receiver
PROTECT FLASHING
The protect circuit is doing it's job....probably the amplifier
output stage is shorted.....have a technician check it..make
sure any / all bad connects are soldered when chassis is out
for service......................T.
Jan 04, 2008 | Sony STR-DE345 Receiver
Protector flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Oct 05, 2007 | Sony STR-GA7ES
Sony STR-DE345 Receiver Logo
119 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
