Question about HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175v all in one Ink Jet printer, scanner, copier
Hi, I hope you can help me. After I print, there is a knocking sound, I think it's my belt (is there anyway I could change the belt or do I have to take it to someone else to do that) or could it be something else, also I have black line under the glass can you tell me how I can get the black off. Hope you can help me....Thank you. Eleanor
  • 43 Answers
Hi Elenor.
With the blech line of dust is easy - if you have a thin screwdriver " _ " one and a torx10. Remove the bezel from the front panel and push with the thin screwdriver in the small holein the panel. While pushing (not hard) easy slide dhe front panel towards the back of the printer. Unplug the ribbon cable carefully. The panel unmasks 1 screw. There are 3 in total. The other 2 are under the scaner cover - pull it with force straight up untill you remove it.
Unscrew the 3 torx10 screws then pull the cover with the glass easy from the back - up lift ti untill the front releases.
Be carefull with all the ribbon cables.
With the other problem...
Where (in witch part of the printer) do you heare the noise?
May be true - becose of the belt but not necessary because of it. You can have a piece of paper or an obstacle in the left or right sice of the printer in the craddle's path, or the spring that pulls the best straight could be weak.
Have fun
Posted on Mar 19, 2008
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Aug 01, 2016 | HP PSC-2410 PhotoSmart All-in-One Color...
WHY DOES MY HP PSC 1610 MAKES A CLICKING/CLANKING SOUND WHEN STARTING TO PRINT STILL PRINTS
I think your printer required maintenance, because printer time all parts working then your printer print. I gas you some points link printer belt, printer header, printer roller..so any one damage or this types of issue create, so i suggest you contact HP printer technician and check it.
Thanks,
HP Printer Support
May 18, 2014 | HP PSC 1610 All-In-One InkJet Printer
I have a HP psc 2175v printer and it says i have a carriage jam. There is no paper in the printer all at this point and the ink carriage moves back and forth fine, the ink was removed adn replaced but...
The cartridges might not be moving back to there rest stop correctly, check the sponge to the far right Also The clear plastic strip running behind the carriage could be damaged or dirty. this strip tells the printer where the carriage is and if it can not read it, it will cause that message.
Hope this helps
Regards GM
Apr 09, 2011 | HP PSC 2175 All-In-One InkJet Printer
All of a sudden it will not print but as soon as u turn the printer on it prints like a test page
may be you chaged the catridge.
It is not the test page it is alignment test page just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 18, 2010 | HP PSC 1510 All-In-One InkJet Printer
Need to install printer HP PSC 1500 all-in- One series
i lost the software of psc 1500 all-in-one can you help me?
Jun 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
RAISE COVER LOOK FOR big silver bar that ink cartridges ride on apply 2 or three drops of 3 in 1 oil to the top of this bar and then try to print
Jan 03, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printer
What printer and software are you using?
Does it do this for anything you print. Example a word document.
Oct 10, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
103 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
