1 check your power to make sure you have 240 volts . 2 verry possible your heating element is burned out.3 you may have a safety thurmo burned out.depending on the brand and model your start switch could be bad on the moter. also depending on the brand and model` the timer could be bad or a burnt wire.
SOURCE: my dryer it got hot
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
SOURCE: dryer gets hot but doesn't
heatman101
SOURCE: My Kenmore Elite Oasis dryer
The first thing to check is the ohm reading across the heating element. that is common to go bad. If not that, there are temp switches(snap switches) to keep it from overheating. If one goes bad, it wont heat. If that is the problem, make sure your venting is not restricted too.
SOURCE: dryer spins but doesn't blow
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101-=
