Question about Maytag MER6772 Gemini Electric Kitchen Range
F9-4 when cleaning upper oven
I have a Maytag Gemini electric stove - when I try to clean the upper oven I get the F9-4 code (which sites are saying is related to the lower oven?) When I try to clean the lower oven it works fine. When I receive the F9 -4 code on the upper oven the door appears to lock fine (I am not able to open it) and it moves to cleaning mode, but then starts to make an electical clicking noise. Shortly afterwards, the error code is displayed, the door unlocks and cleaning stops. Please let me know if you have a solution - thanks.
  • 2 more comments
  • Blacklion9 Feb 24, 2008
    I experienced the same problem today. The lower door is now locked and it will not open. Any suggestion?
  • Anonymous Mar 19, 2014
    started a clean cycle and noticed I left rack in.opened door to take out but door locked and now I can't close the door
  • Anonymous Mar 21, 2014
    self clean system will not work press both upper and lower buttons and then start and then it stops and message comes up saying "door"
  • Anonymous Mar 30, 2014
    cleaned oven, door will not unlock ovenis cooled down
    President:
  • Maytag Master
  • 2,651 Answers
Its related to the self clean ltach motr, if you pull hte unit out and drop teh rear panel, approx halh way down on theright side( when behind unit) thers asmall lock mechinisn mavbe 1.5 round, with a connecting rod 2 wires and a witch, well that motor sometimes as it heats looses connection with the switch. the switch is monitoring door positoin so if it loses contact it thinks the door is open and will trigger a code. the entire latch is replacabel (FRont to back comesa sone assy latch motor swittch and rod. 2 wires connect it and 2 screws(by front latch secure it. if youtry to replaceit your self i giveyou the heads up to lie a yard stick on top of latch before removing old latch (thos will keep the insulation in place) andthen when installe ing new latch also use hte ayrd stick ontop to keep insulation inplace!!!!!
Posted on Mar 10, 2008
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Stove oven will not come on get a code F1-1
Put in a new thermastat in the top oven and it works great. Thanks for the advice(from other's having problems).
My Maytag was older than I thought, so the thermastat was not available on line, but found one at a repair shop that worked. Thanks!
Jan 10, 2009 | Kitchen Ranges
Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Oct 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Ga Stove/Oven 30"
Hello Steve
Welcome
You said , We lost the instruction manual...can someone show me how to turn on the self-cleaning function on both the upper and lower ovens? Thanks, Steve O.
The instructions are to long to put in here and will not fit.
so here is what you asked for at the original site.
Whirlpool owns Maytag now so your manual is at this site and the cleaning page starts on page 12.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
Thank you for using Fixya,
Huuum
Please remember to leave a solved rating!
Oct 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
450 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
