Question about Sanyo Bag-Free SC-240 Canister Vacuum
Hi, my sanyo pulse 1500 bagless vacuum has very little suction.
Can you help? thanks
    President:
  • 1,673 Answers
If the vacuum will run without the hose attached, does the suction seem ok at the opening where the hose goes into? If so, then you have a clog in the hose or down below where the dirt is first sucked up. If suction is poor at the vacuum, then check the filters, they go bad after awhile.
Posted on Feb 29, 2008
Hi, my Bissell 3920 has lost almost all of its suction. I checked the hoses and tubes but did not find any blockages. Filters are clean. Thanks.
Hi, Have you checked and made sure the floor plate is secure and tight without any gaps around the edges? If that's ok then check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself
Nov 27, 2011 | Bissell 3920 Bagless Upright Vacuum
Hi... I'm getting no suction from the hose at all. Have checked hose for clogs but couldn't find any. Cleaned filter. Have no suction when vacuum is in position to clean floors. Checked for...
Anyone owning a bagless vacuum cleaner,
needs to own a small air compressor, to blow
it out after every 2 or 3 uses
Otherwise is will never work,too clogged up
Jun 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
There is little to no suction. What do I check to fix it?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright
Vacuum not working
heatman101
Dec 24, 2010 | Bissell 3576 CleanView II Bagless Upright...
Problems with Dyson DC14 Animal Bagless Vacuum very little suction coming from the hose. cleaned filter and suction has not improved. Please help. Thanks
Two possible solutions come to mind. First off, there is a clog in your hose. If you have another vacuum, try using the hose on that one to **** it out.
If that doesn't work, you may need to have the clutch replaced. Check your warranty. The clog wont be covered, but the clutch will be,
Oct 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction
Hi there SmartAlec from NelsonVacuums.com.au here. The problem is going to be the filter. THis kind of vacuum basically replaces the bag with a simple filter and the vacuum cleaner simply pulls all the dirt on to the filter so as soon as you start vacuuming you lose suction. The more expensive bagless vacuums spin the dirt through a chamber to minimise the material getting to the filter but unfortunately that wont help you. I could be wrong but i fix vacuums for a living and see this all the time. ITs a bit of a silly design in my opinion. You can test my theory by removing the filter and really thoroughly cleaning the little cracks with a brush or better still an air compressor and the suction will improve...untill you vacuum dirt that is.
Hope this helps, if you want more info just drop me an email.
Happy vacuuming :)
Aug 30, 2009 | Vacuums
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Pulse Bagless dust press system vacuum cleaner I need to download the instruction manual
Dear Customer
please check the following link for
Sanyo Instruction Manual Upright Bagless Vacuum Cleaner SC-150, SC-180
http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sanyo_upright_bagless_vacuum_cleaner_product_list.html
please rate this,Thank u
Dec 16, 2008 | Sanyo Vacuums
Hi my vacuum (Russell Hobss 2200 bagless HEPA) seems to have just enough ( not loads) of suction til it reaches the cleaning head. the head does not appear to be blocked - but there is then almost no...
Generic problem for all Vacuums
Hi my vacuum (Russell Hobss 2200 Bagless HEPA)
Hi my vacuum (Russell Hobss 2200 Bagless HEPA) seems to have just enough (not loads) of suction till it reaches the cleaning head. The head does not appear to be blocked - but there is then almost no suction at all.
It also makes loads of noise when on- and an even louder noise when turning off.
is it fixable or is it dead?
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Well there seems to be maybe a few problems, the head may be clear, but the hoses could be clogged and or the HEPA filter could be clogged as well – if the hoses and wands are clear and the filter clean you may look @ a motor replacement depending on the cost or to buy a new vacuum and in some instances you can trade in your old vacuum for a new one – but check it fist from the suction head thru the hoses, wands and filters, B4 you decide to purchase a new one or to replace the old motor with a new one depending on cost. A rule to live by – the item cost more to repair that to replace – replace the item, if the repair cost (as an example) say $50.00 to $60.00 and to buy a new one would cost $100.00 – buy a new one.
Don – The Vac Man
Apr 21, 2008 | Vacuums
Sanyo Bag-Free SC-240 Canister Vacuum Logo
248 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Thatvacguy.com
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
