Turn
off the Xbox 360 by pressing the power button on the front of the
console. Afterward, shut off your modem by unplugging its power cord.
Insert
one end of the Ethernet cable into the Ethernet port located at the
back of your Xbox 360 console. After that, insert the other end of the
cable into your modem.
Replug
the power cord into your modem to turn it back on. Once it is active,
press the power button on your Xbox 360 to turn it on.
Navigate
to "My Xbox" then "System Settings." Afterwards, select "Network
Settings" then "Test Xbox LIVE Connection." You will be notified
on-screen if the connection is successful.
Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
1.Simply connect your xbox 360 to the internet with the Ethernet cable. Go from the xbox 360 to a router or directly to your internet source; internet modem or internet cable if you have fiber optic internet connection. 2. Turn on your xbox 360 and go to the xbox live tab. 3. Go wher it says Join and follow instructions. You can put your credit card info. or buy a prepaid xbox live card
If you are trying to connect to xbox live you should plug in your ethernet cable to the back and than turn on the xbox 360 and select xbox live..
If you are trying to "hook" recieve visuals plug all the cords the xbox came with into the right places and plug the opposite ends correctly into the tv than make sure your cables are on the settings tv not hdtv than find the input your tv must be on to ie: input1 or source
Before you
connect any cables, turn off your router, modem, PC, and Xbox 360
console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem
and the other end to the Ethernet input port on the back of your
router.
With another Ethernet cable, connect one end to one
of the router's Ethernet output ports. Connect the other end to your
PC's Ethernet port.
With the third Ethernet cable, connect
one end to another of the router's Ethernet output ports. Connect the
other end to the Ethernet port on the back of the Xbox 360 console.
Turn on your modem, then your router, then your PC.
Make sure your PC can access the Internet. If not, you may need to
configure the router for Internet access. For help configuring the
router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console and sign in with your profile.
If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
you can go to your routers website and enter it manually. Type 192.168.1.1 this might be it or try 192.168.2.1 or 192.168.1.100
when it shows your routers info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just 0.0.0.0 if it doesn't give you two. the gateway is just your routers ip address.
what else you can do is do port forwarding. But the xbox is not a static ip address so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is 192.168.1.1 you can use 192.168.1.23 i use 192.168.2.15 but you may not have the 2 in yours.
you have to pay for xbox live. If you do not pay for xbox live then you cant get the internet for your xbox 360. Its one thing i hate about having an xbox. Hence the reason for me getting the playstation 3. I hope this has helped.
try starting your xbox up with out the hard drive play a game for a little while. and plug your drive back in. This is a hard drive problem. But remember the xbox has 4 memory chips that keep info even when you shut it off.
Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console with no disc in the disc tray.
If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
