What key do I hit to make the computer brighter while using the plug in
  • blackie12 Feb 24, 2008
    Thanks this was helpful. Would the sunshon button be F2
If its plugged in then its already at max (im assuming ur using a laptop) if ur in power saving mode then hold down fn and press the buttons at the top that has the sunshon thing on it
Posted on Feb 24, 2008
MY SCREEN WENT DIM ANDI FOGET HOW TO BRIGHTEN IT
Laptop. Make sure it is plugged into the mains as the battery saver may have activated. On my HP Laptop, pressing the F3 function key brightens, F2 makes dimmer.
On computer monitors, you need the menu button which will be somewhere at the front of the monitor either on the face or just underneath out of site. Press menu to bring up the options, use another button to scroll to brightness, press another button to select, one of the button you just used to make brighter and then menu to save out.
Mar 29, 2017 | Computers & Internet
How does one make the screen brighter on a laptop computer
Normally there should be two keys to turn up and turn down the bightness on the top of the keyboard partnered with the F keysLook for a lightbulb symbol, one showing it getting brighter and one dimmer. First press the key a few times and if the screen gets dimmer or brighter you are good to go, but sometimes it might be the second function key, so you will have to look for the key on your keyboard to activate the second function, and normally that key is called the FUNC or FN key, and should have the same color and the second function options. So hit that key, by either pressing it once, or holding it in.
Apr 02, 2013 | Packard Bell Computers & Internet
Usually when i plug in the charger to computer the screens gets brighter, it no longer does that, my screen is very dull and not bright how can fix?
you can change that in power settings right click on the battery bottom right of the screen hit change power settings u will get options u want to change power settings look at the options you want to make it stay brite all the time right now you have it set to be brite only when plug is in change the option when its unplugged to brite also
Aug 10, 2012 | Acer Aspire 7741z
How to maximize laptop screen brightness
Turn up the brightness by the keys on the keyboard. Most times you will have to Press and Hold the FN function key at the lower left portion of the keyboard, then hit the key that controls the brightness.
Also on laptops you can change the position of the lcd screen to make things appear brighter or clearer.
May 31, 2012 | Computers & Internet
Aspire 5110
So does it sound like your laptop is running and booted up all the way except the screen is blank? if so try the steps below:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 08, 2012 | Computers & Internet
My mytouch 4g lcd backlight is dim but it gets brighter when i plugin the charger, is it the lcd? Or the connector to the lcd.
I'm not sure what a Mytouch is but on laptops if you don't have the power cord plugged in the display is normally dimmer or darker to preserve energy because it is running off the battery. You can make it brighter to some degree by pressing the correct keys on your keyboard. Once you plug the power cord in, laptops automatically display a brighter screen. This is all normal protocol.
Mar 21, 2012 | Computers & Internet
I am plugging the monitor up to my laptop and I can see the screen show up on the lcd but it is very very dim. How do I make the lcd display appear brighter? Thanks.
1 Check the brightness control on the laptop should be a Fn+ ( key on the keyboard)
check the user manual for the laptop function keys.
***I hope this helps. Have a great day!***
Jun 22, 2010 | ViewSonic VX2235WM Monitor
How can i make my screen brighter?
usually there are keys that you press in conjunction with another key like the Fn key and a key that looks like a bright Sun, or a Dark Sun, shape, on one of the keys usually on the number keys on top row under Function keys. So you press the Fn key and at same time. tap the Bright sun key, and it will step up in brightness, plugging in the adapter also makes it brighter too.
Mar 01, 2010 | Acer Aspire 3000 Notebook
Hi how do i get the screen to be brighter
Usually if you have a lcd or crt the brightness control will be on the monitor itself. If you have a lap then it's usually a "fn" key. Look on your keyboard for one or two keys that have a sun or light or something like that one them. You will most likely have to hit the function key (fn) first then the brightness keys.
Oct 25, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
