How often do you idle this blazer. if you idle alot this this adequetly lubricate the cylinder walls and what happens is "fuel wash", which then progressively wear the cylinders,rings,and piston ring lands and grooves. you may also have a throttle body/injector problem causing over fueling. any sign of smoke?
how did you find out that it is pumping gas into the oil? is it carbuerated
