We have F02 error message. We have cleaned out the white plug and filter. It has not worked. Is there any other area that needs to be cleaned? Our drain hoses do not seem to be blocked. There are no blockages inside tub area either. Please help.
If you have cleaned the drain pump and checked ALL the drain lines (this includes the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump), then you may have to replace the pump.
Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and cannot pump at the correct volume to complete the drain cycle, the error code will continue to appear until the pump is replaced.
The following link explains how to replace the drain pump:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I hjave listed also have helpful exploded view parts illustrations to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
Hello &
Welcome to FixYa
F02 is a drain error in your Kenmore washer, if
the unit is unable to drain then after 4 minutes it will display sud and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
