Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer LSQ9264HQ
My washer is 9 years old.
When trying to start if just keeps filling continously.
Never overfills, never stops.
Won't go on the the next stop.
Solution #1 was actually posted by zeida3
Posted on Feb 24, 2008
Either you have a faulty water valve, which would either need to be fixed or cleaned, or you have constant power to the valve caused by a problem in the controller which does not allow the cycle to advance. If, as you say, it does not overfill, then apparently your water level control pressure switch is operating and causing the pump to turn on and drain as fast as it fills.
Whirlpool 'quiet wash plus' top load washer
the washer is over filling because the float part is bad see the link below for details Whirlpool Dishwasher Overflows Replace Float W10345285
Jan 07, 2018 | Washing Machines
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Whirlpool calupso FL (over fill) flashes....The manual says the washer will beep every 10 seconds and the pump will cycle one half minute on, one half minute off until the over fill switch is reset or the...
Hello & Welcome to FixYa
FL error indicates flood condition and is caused due to any overfill condition that occurs inside the washer. To clear the display you can press and hold the STOP/CANCEL button. Usually this error is caused when overfill switch trips due to excessive water in the tub. You can also try to clean the drain hose and check the water inlet valve. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont stop filling
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Apr 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine overfills with water at start up after two years in use.
If the washing machine operates and cycles correctly, and only problem is overfills, then you have a bad water level switch or a bad membrane sensor (water level sensor).
If instead the machine get stuck on filling, and does not stop even if you advance timer, then the inlet valve is stuck on open, or the control board is faulty.
If machine is only two years old, call manufacturer and complain, even id limited warranty is one year, they may cover the part cost the same if they decide this was a factory defect (if it is inlet valve) coming up after two years.
Mar 17, 2009 | Whirlpool Washing Machines
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRLPOOL TOP LOADER OVERFILLING WATER
While it is filling up try this. Unplug the washer from the wall, if the water still runs then you need to replace the mixing valve. If the water stops then take the screws out at the base of the console and flip the controls back. Look for the clear hose that goes to the water pressure switch and make sure that it is connected. If it is connected take it off the switch and blow through it to see that it is clear of any obstructions.
If this only overfills after the first ore second wash then you may have the slow drain and the drain hose is in the downspout too tight.
Possible items needed;
#1 mixing valve
#2 pressure switch
#3 plumber
Jan 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
214 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
