Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Feb 24, 2008
Garage door wont open or close with remote when light is on
  • 2 more comments
  • pradhyumna Feb 11, 2009
    my garage door doesn't open with remote. it was working till yesterday. I dont nderstand the problem...will anyone out there help me out?
  • Anonymous Feb 11, 2009
    remote wont open the door but when i push the wall unit it open
  • Anonymous May 11, 2010
    Do you have any lights on your wall control at all? What make is your opener?
  • Vince Heuser May 11, 2010
    Is light on wall control flashing or solid?
Anonymous
Level 1:
  • Contributor 18 Answers
  • Posted on Feb 19, 2009
Anonymous
Contributor
Level 1:
Answers
18
Questions
0
Helped
13311
Points
45
Check to make sure that your sensors are correctly aimed and you have a solid green light on one of them. If the opener works only on the wall pad (especially if you have to hold it down) then you are bypassing the sensors.
Check those first and advise.
1helpful
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
2answers
Door wont close
Roger, does lights blink when attempting to close door?? If so it is the photo sensing eyes. Be sure they are not blocked and properly lined.
If all is ok, replace the photo sensors. Hope this helps
4helpful
My garage door opens fine, just wont close with remotes. Lights just flash. I have to use the opener in garage and keep the button pressed in till the door is fully closed or it will reverse.
Clean both safety sensors lens located at the bottom of the garage door frame. Make sure both sensors led lights are lit. If not they are out of alignment and you will have to loosen the wing nut on the sensor that is lit and move it, trying to get the other sensor to light.
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Door wont close with remot
Your door sensors may have been bumped and are no longer pointing at one another. Tweak them until the small light on each sensor is on and glowing steadily.
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Garage door opener remte built in in my van suddenly stopped
TRY DISCONNECTING THE WIRE TO THE WALL BUTTON. IF THE VISOR REMOTE NOW WORKS YOU HAVE A BAD BUTTON.
HOPE THIS HELPS
2answers
Garage Door Remote
find attena and point it to your door if this does not work try adding a piece of wire to attena and making it longer also always check batts...
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
