Question about Archos 605 WiFi Digital Media Player
Recovery code 102
I'm am giving the option "System is damaged. Would you like to recover it". When I chose the repair option it goes through a cycle but returns to the option screen. Ideas on how to repair it?!
  • Bodiddly Feb 24, 2008
    How do remove the batteies? The users manual does not show how!
You may want to try formating the disk. this may also mean that you have a problem with your hard drive. remember that formating the disk will erase everthing that you have on your archo. if that doesnt work, then you can take it to the place where you got it from and they will fix it for you.
good luck!
Posted on Jun 26, 2008
    Brigadier General:
  • 6,966 Answers
Your post/description indicates a possible problem with the firmware. It would seem that the Archos 605 would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
There are several versions of the 605, you need to determine which one you have.
Things you can try:
1. Do a soft reset. Press on the power button for about 15 seconds;
2. Do a full/hard reset by removing the batteries and pressing the master reset button;
3. Try again the Systems Recovery. You may need also to format the internal HD but that would mean you loose whatever data is inside.
Alternately, you may need to update/re-install the firmware. A more complete and better explained firmware update procedures are here. Briefly, you have to download and save in your PC the ???????.aos file (there are several versions of the firmware. You need to determine which one is appropriate to your model), connect your 605 to the PC, copy/paste (drag & drop) the said file to the Archos device listed in "My Computer" (you may have to overwrite the older copy), disconnect 605, proceed to System Settings, tap on "Update Firmware". Follow on screen instructions.
If the above is not corrective, am afraid that your unit has been partially bricked. Some have reported serious hardware or firmware problems with the 605 that would require replacement by the manufacturer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 24, 2008
  • Louie  Role
    Louie Role Feb 25, 2008
    Hi again,
    Unlike the 604Wifi, the 605 doesn't have a replaceable battery, It is user non-removable. Sorry. However, I was made to understand that for an extra US$49 something, you can buy an external battery pack that clips to the base of the player.
    Cheers.
  • Louie  Role
    Louie Role Feb 26, 2008
    Glad to be of assistance and appreciate the rating too.
Advent roma 1000 will not start up.
Hard disk drive has failed. Replace it.
Mar 03, 2017 | Advent Computers & Internet
Recovery code 2 / system is damaged. would you like to recover it ? No Repair Format Disk Any body have any ideas ?
hey, did you sort this out? If so, how?cause I have the exact same problem...If I manage to be fast enough to press the button to "recover" or "format" before the screen freezes then it just goes into recovery for ages but accomplishes nothing. My computer doesn't recognize my archos so oI can't upload anything or update anything.?????
Jul 11, 2011 | Archos 504 500870 Digital Media Player
When i start my pc, os not found. the recent OS is windows vista home primume and i was not be able to burn the recovery disc in recovery partition, how can i recover my file? and where i can find to buy...
use windows vista home premium cd
boot using windows vista cd
after setup run chose repair your computer this option will detect your previous windows
it will direct you to system recovery option and this process wil automaticly repair and restore you system, wait and follow the instruction until finish
i hope this helpful
thank you for using fixya
Feb 07, 2011 | HP Compaq Presario V6000T 15.4" Notebook...
When i turn it on it goes to a white screen with a blue line across on the very top it says recovery code 108 the next line says "would you like to recover your system?" then it gives me three...
when i turn it on it goes to a white screen with a blue line across on the very top it says recovery code 108 the next line says "would you like to recover your system?" then it gives me three options no, repair disk, and format disk. I dont know what to do cam body help me?
Nov 04, 2010 | Archos 605 WiFi Digital Media Player
When i switch on my archos 405 2gb it comes recovery code 102. it gives three options ''no'' ''repair'' and ''format''. i clicked on repair but it restarts and it comes the same thing again. What am i...
I think it means 'File system FAT error'. Use the solution above by IPOD tech for reformatting the hard disk. It should be OK. I used the solution to reformat my archos7 last night, and it is working fine.
Jun 13, 2009 | Archos 405 Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
Archos 404 could not start
it sounds like the partition that hold the recovery files has got damaged,i suggest you talk to the manufacturer or supplier on how to overcome this problem,if it was a pc i would say format hard drive & re-install the software but its not .
good luck
Terry
Mar 23, 2008 | Computers & Internet
Archos 605 wi fi fault
have you tried resetting the machine on the bottom their is a tiny hole put a reasonable sized safety pin through that you use for a babys nappy.I found this reset my archos!!!!
Nov 20, 2007 | Archos 605 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
1,347 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
