Touchpad is too sensitive - Computers & Internet
  • Anand Srinivasan
    Anand Srinivasan May 11, 2010
    what is the driver that your touchpad uses....
    Scholar:
  • 148 Answers
Which desktop is using?
do u have the proper driver for it?
try to download the updated driver from the net
and install it
Posted on Feb 24, 2008
Jumping print size
If there's a touchpad icon in the notification (tray) area on the lower right, it might have an option to lower the sensitivity. The Control Panel should supply an applet to the touchpad. The best answer is to get a mouse and disable the faulty touchpad.. the can be replaced too. Once a touchpad gets sensitive like that, the mere tapping on the keys of the keyboard can cause the pointer to move on you.
Nov 20, 2013 | Computers & Internet
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Please tell me how to rduce the sensitivity of touchpad on my Advent laptop that is 3 months old before it drives me to insanity!
It almost seems like magic when you type something on your notebook and the cursor jumps over the document because your palm touched the touchpad. So your text appear all over the screen and not where it ought to be. How do you solve this problem?
It is because of the input sensitivity of the notebook touchpad is too high. Many laptops come with a special driver (Ex:. Synaptics TouchPad) that can reduce the sensitivity of the touchpad. Without using such a driver, the touchpad is integrated as a normal PS/2 mouse and this means very high sensitivity. To solve this 'highly sensitive' problem,
  • Right-click on 'My Computer' and then select 'Properties' in the context menu. This opens 'System Properties' dialog box.
  • Click on the 'Hardware' tab and then on the 'Device Manager'. Here you will ?nd an entry titled 'Mice and other pointing devices' in the 'Device Manager' window. When you double-click on this entry, it shows the touchpad as a PS/2 Compatible mouse.
  • Right-click on this entry to go to the properties of the touchpad, select 'Advanced Settings', and then click on 'Sample Rate'. You can reduce the degree of sensitivity here.
  • Follow this tip and you can solve the 'jumping cursor' problem easily.
Jul 15, 2011 | Computers & Internet
How do I change sensitiveity on my msi touchpad
HI, For you to change the sensitivity of your touchpad, you need to go to Control panel > then go to mouse and pointer devices > then there should be a tab for your touchpad.. now you can change the sensitivity of your touchpad to your preference.
Thank you for using Fixya.
Jul 03, 2011 | MSI Computers & Internet
My acer aspire 5742Z touchpad is too sensitive or I don't really know how to use it. Every time I touch it something stupid happens on screen. Now it has turned my screen dispay side on and I have to use...
Definitely your touchpad is TOO SENSITIVE!
To modify the sensitivity just go
START > CONTROL PANEL > MOUSE/TOUCHPAD and adjust there the sensitivity by dragging the cursor to the LEFT until it reaches the middle.
In PROPERTIES just re-invert the functions of your touchpad to get rid of the mixed axes.
Mar 03, 2011 | Acer Aspire 5742Z-4200 Notebook
My touchpad has lost sensitivity. How do I fix it?I have to use the right.left bars underneath once I make a selection.
It seems that the sensitivity for the touchpad has dipped. Hoping that you might be using Synaptic's touchpad.
See if this helps..
1.. Click Start then click Control Panel.
2.. Click Printers and Other Hardware then click Mouse.
3.. Select the Device Settings tab.
4.. Highlight Synaptics TouchPad in the list and click the Settings
button.
5.. Click the plus sign next to Sensitivity to change the sensitivity settings of the touchpad.
If you are not getting any positive result from changing the settings, you can uninstall and re-install the drivers for the same and then check it once again. If all fails, this leads to the result that the touchpad is itself damaged and you need to replace it.
Cheers!
Apr 04, 2010 | Computers & Internet
Is there download software that will alow me to adjust my touchpad sensitivity? The touchpad on my Dell 610 laptop is much too sensitive. I cannot find the usual software on my harddrive used to decrease...
If you go in to control panel in Windows XP and in to the Mouse option you can control the mouse speed.
Alternatively the downloads for your laptop can be found here.
Dec 15, 2009 | Dell F3534 Touchpad
Touchpad too sensitive
You should find the settings are either under the mouse settings, or under the touchpad's own controls, in Control Panel.
Jul 01, 2009 | Dell Inspiron 1525 Laptop Flamingo Pink
Dell xps M140 laptop touchpad
I have the same problem and it sucks. Not sure how to fix it.
Feb 15, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
398 people viewed this question
David Payne
David Payne
