Sansui 5500 Led lights on right and left side of display seem to be burned out...can you get replacement bulbs and is it difficult to replace/take cover off
    Genius:
  • 1,175 Answers
Yes. You can get replacement bulbs and no , it's not difficult to get the case off. Most likely 4 screws on the sides and a couple on the bottom
Lamps at
http://www.vintage-electronics.cc/
or www.partsexpress.com
Posted on Feb 24, 2008
Brake lights rear blinkers quit working when turn signal is on flashes really fast
You simply have a burned out bulb or bulbs. With the key turned on turn on the directional for the left side and then the right side. Typically one bulb is blown and the opposite side works normally. Observe the normal side and note which is the flashing bulb. It is the flashing bulb on the other (malfunctioning) side that needs to be replaced. To replace the bulb you must remove the entire brakelight assembly, which isn't difficult. Open the trunk and locate the electrical harness that lines up with the brakelight assembly. Near the harness, locate the two (possibly three) nuts or wingnuts that attach the brakelight assembly to the car. Once the nuts are removed, the assembly can be pulled off the rear of the car. After replacing the bulb, be sure to test the operation of the new bulb before reassembling everthing.
Mar 18, 2015 | 2002 Ford Taurus
Bulb on ge microwave keeps burning out
Hi anything is possible being that you even replaced two different brands of bulbs. I don't think the wiring harness is the problem but like I said anything could be the problem. Might I make a suggestion. Why not replace both the left and right side bulbs with LED bulbs with the same base configuration. Maybe that just might be able to solve your problem. I would like to know if it does. It also seems that a lot of others are having the exact problem. Good luck.
Marty
Apr 14, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
TURN SIGNALS
Hi
Did you check the fuses for the turn lights? Do the
parking lights work? If the parking lights work then you probably have a
problem either in the switch or in turn signal module thing.
The burned out bulb is what might be causing it not to blink... if one bulb is burned out you gotta replace it, make no difference if front or back,the left blinker will not work if the left front or rear bulb is bad.
same with the right side. if the front right or rear right turn signal
light is burned out it will not work.....get replacing the bulbs.Hope this solves your problem.Please rate me if my solution helped you.
Regards,
bonefirediv.
Apr 12, 2014 | 1988 Ford Taurus
Left turn signals won't flash, Right side works fine. Replaced front and rear turn bulbs (rear was burned out). Bulbs come on fine on the left side, they just won't flash.
Gday mate, we had a problem with another late model vehicle similar to that, the bulb that was put into the reverse light was not exact brand product ( ohmage was slightly wrong ) and fowled up computer, correct bulb in place and disconnect battery to reset K A M ( keep alive memory) problem solved, BEWARE, some vehicles cannot have KAM reset except for dealer computer tethered reboot , just try putting the factory correct bulb(s) in and see how it goes, geoff. hope this helped.
Feb 11, 2012 | 1998 Buick LeSabre
Left blinker flash fast, hit brake left blinker goes out left taillight goes out but both backup lights come on
Usually a fast flashing signal is because one of the bulbs is burned out or shorted out. If the signal and brakes use the same light which many cars do then check the wiring to it and replace bulb. If burns out again then it has a short between the signal switch and the actual light or the brake wiring to it is shorted.
Sep 03, 2010 | 1999 Chevrolet Silverado 1500
I have a 1993 Chevy Blazer S10 Tahoe and the speedometer light is out. I can see everything on the right side of my instrument panel at night, but nothing on the left. How do I change that bulb (or bulbs),...
You have to remove the instrument cluster to replace the bulbs [the bulbs go in from the backside] Not to difficult of a job but I would suggest replacing every bulb in the back while you have it out as they are all the same age and it seems that once one burns out the others aren't far behind. I don't know the bulb number but most parts stores or a GM dealer can figure out which ones you will need. The bulbs are held in by small plastic bulb holders that you push gently and turn to remove from the back of the cluster.
Jun 25, 2010 | 1997 Kia Sportage
Replace radio led display
the radio doesn't have a LED, it is a LCD, LCD display's have no light of there own, LED's do, the problem u have here is that the tiny bulb inside the radio behind the display is burned out, you need to pull the radio out and remove the top cover of the radio, right behind the display you will find a tiny twist in bulb socket, remove it and replace the bulb.
Oct 09, 2009 | 2005 Mazda 6
StopLight/Brake Light burns out about every other month
have you checked the fuses they should burn out so the bulb doesn't try putting a lower amp fuse in, even if it keeps blowing it is cheaper and easier to replace
Aug 27, 2009 | 2006 Hyundai Sonata
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
272 people viewed this question
 Grubhead
Grubhead
