Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
POWER LIGHT BLINKS 5 TIMES
THE POWER LIGHT BLINKS 5 TIMES. IT SAYS IN THE MANUAL THAT IF THAT LIGHT BLINKS 3 THAT THE LAMP IS NOT IN CORRECTLY. IT DOESNT SAY ANYTHING ABOUT BLINKING 5 TIMES. YOU HAVE ANY IDEA WHAT THE BLINKING OF 5 TIMES MEANS?
  • 3 more comments
  • KENNETH929RR Feb 24, 2008
    THANK YOU SO MUCH "SLINTERIORS"
    i was waiting to see if it fixes it but ill take your word for it, lol ttyl thanks again
  • Anonymous Mar 01, 2008
    Had the same problem. On/standby lamp blinking 5 times.
    TV would be on for minute or two with sound, then go "off" for a minute or two, then repeat this cycle endlessly.
    It was the lamp - needed to be replaced - really easy - couple of screws. I think the usable life is ~4,000 hours - ours had 6,100.
  • KENNETH929RR Mar 07, 2008
    well thanks for all the input. my tv was still was under warranty. the tech. came to my house, i told him what was happening. he opened up the tv from the front where the lamp is at. he pulled it out and the bulb was out. replaced it and back to new again. damn if i didnt have that warranty, it would of cost me just for the bulb $250.00 and thats not even counting labor. labor would of been another $100.00 in something. so the word for today is "WARRANTY" lol thank god i purchased it!
    thanks again for the input. it definetly helped when i called it in so i could give them an idea on what was wrong.
  • Anonymous Mar 22, 2014
    the power light is blinking 5 times when power is on
  • Sony Master
  • 8,617 Answers
That's the LA-3 LCD projection unit. 5 blinks on that model means a lamp driver error. You would need the service manual to diagnose exactly whats wrong with the system. I have included a link where you can get the entire 121 page service manual for your set if you would like it. It cost 15.99 and they will email it to you and provide free support to help you diagnose it. Here is the link if you would like the service manual.
http://servicemanuals.vstore.ca/
Posted on Feb 24, 2008
  • Sonny Berry
    Sonny Berry Feb 24, 2008
    Dont forget to give my response a rating Thanks.
Lamp light blinks 5 times
The lamp might be at the end of its life. Change the lamp.
Dec 19, 2012 | LG RU-44SZ61D 44" TV
Tv doesnt show anything
Got (if model listed is correct) any blinking lights?
Set has a self check:
Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 29, 2012 | Mitsubishi WD65737 65" DLP TV
TV doesnt turn on
Replace your Lamp XL2400 Mats Has them 1-800-628-1118
Mar 24, 2010 | Sony KDF46E2000 46" Projection HDTV
I have a al1216 copier of sharp. Now didn't anything flashing only 4/h frequently
H4 00 Content Too cold fusing section Detail The temperature does not reach the preset value within the specified time (3 min. in usual modes; 5 min. in curl correction mode.) after the power relay is turned on. Cause Thermister defective Heater lamp defective Control PWB defective Thermostat defective AC power supply defective Interlock switch defective Check and remedy Check heater lamp for blinking with SIM5-2. If lamp blinks properly: Check thermister and its harness. Check thermister input circuit of control PWB. If lamp does not light: Check heater lamp for broken wire and thermostat for operation. Check interlock switch. Check lamp control circuit of AC PWB and control PWB. Clear the trouble with SIM14
Nov 02, 2009 | Sharp Office Equipment & Supplies
3 flashing lights
the 3 blinking LEDs mean the lamp may be defective. Be sure the lamp is making contact with the sockets within the lamp compartment, also make sure the lamp is the correct one for your model. The set can be reset by unpluggimg the power cord for 5 minutes then plug it back in, if the 3 LEDs still blink check the lamp if its making contact and its the correct lamp for your model, suspect the ballast
May 25, 2009 | Samsung HLP6163W 61" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
No Picture, power button blinks 5 times and just clicks
If you dont have the manual, download it from internet. It should tell you what the blinking light is indicating. My friends tv was blinking 3 lights around power button and the manual I downloaded correctly stated it was the lamp that needed to be replaced. I also found some other interesting info via the internet. There is a way to get into the Service Mode of a Samsung TV. Try doing a Google search for Service Mode for your model... Good Luck. PS the lamp itself was pretty expensive but installing it was not hard to do.
Jun 23, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
549 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
