Question about RCA 20F420T 20" TV
20" rca intermitent power
Heool, 20" rca powers up for about 20 to 25 minutes then dies have to wait 5 or so minutes befor it will power up again and repeat problem.
any help is appriciated,
htanks
Bruce
  • lois1952 Mar 09, 2008
    I turn on my TV and it turns off anywhere from a few seconds to longer
Puede ser el mosfet o el optoacoplador
Posted on Mar 10, 2008
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
Jun 16, 2015 | Cars & Trucks
Intermitent power fluxuations with instrument cluster,power locks,and blower motor
Did you try going in to settings, accounts, Backup and reset to factory. do you have a restore on google?
Mar 01, 2014 | Ford Taurus Cars & Trucks
My rca d52w20 power light will come on bright then fade out, tv will not come on till after several trys. what could it be? Light does not flash. Have to wait about 4 or 5 minutes between trying to get it...
DM power supply board might have dying capacitors like bulging,puffing up on it tops or cold soldering capacitors.U have tools like a soldering iron,desoldering pump or a roll desoldering braids,a roll of solders and know how to do basic soldering work?Yes,try website like Tvreparworld.com to buy a capacitors kit they put together,so u can replaced common dying capacitors parts.
Jan 22, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca projection tv
Capacitor on Deflection board cp150 2200uf 16v if it is puffed up on top it is bad 2 more caps cp114 cp120 220uf 35v replace them if cp150 is bad.they are green with gold writing on them.
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Tv will not come on immediately...
3 capacitors cp150 2200uf 16v if it is puffrd up on top then it is bad ,other 2 caps cp114 cp120 220uf 35v they are green with gold wring on them located on Deflection board . Resolder all pinns on FBT on same board.
Dec 26, 2008 | RCA D52W19 52" Rear Projection Television
Problems powering up
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Dec 13, 2008 | RCA D52W19 52" Rear Projection Television
Intermitant transmitting
check the TV volume. it must be 50 percent or better or the headphones will stop working after about 5 minutes.
Jan 26, 2008 | RCA WHP141 Consumer Headphones
RCA D52W20 tv will not turn on
mine does the same thing obviously it is a high voltage problem with the power supply or flyback transformer,we have power outages all the time more thank likely it was the colprate good luck ,my suggestion do what im doing throw it in the trash and buy a new one ,it will cost more to repair we live in a throw away society they dont make anything worth the crap any more ,tvs used to last 25 years now if your lucky 5.
Aug 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 20F420T 20" TV Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
