Question about Pioneer PD-R555RW CD Recorder
Disc does not spin
Recently bought pdr 555 and seller said it worked just before shipment. When blank disc is inserted, the pdr flashes different CD modes for about a minute then says "check disk". The disk is not spinning. The electronics (amplifier) seems to be working and there is output on the earphone jack with an analogue input.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
Please check my tip "Repair for failure to recognize any type of CD for the Pioneer PD-R555RW" in the Tips & Tricks section. It is a hardware repair for apparent failing capacitors, and fixed a problem like this for me.
Posted on May 06, 2009
  • Pioneer Master
  • 19,396 Answers
First do a lens celeanup, just in case.If it does not work It may be the motor. But before opening it I suggest to check if it is under guarantee.
Posted on Feb 24, 2008
  • Ginko
    Ginko Feb 24, 2008
    If the cd does not spin at all, not even when you just close the tray with a cd on it, then is likely to be a motor related problem, then you need to open and test it. If it spins but cannot read disk then may be a lens problem, easiest mainainance you can do in this case is cleang them.
Why does my CD player say no disc?
IS IT A RECORED ONE, OR STORE BOUGHT, SOME HOME MADE ONES WILL NOT WORK.
Jul 07, 2014 | Audio Players & Recorders
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
My Pioneer PDR 555-RW keeps reading Mon1 or Moni when I try to record my CD from my mixing board. I need to send this wedding music, and it is trapped in my board. HELP!
That's just a MONITOR indication. It means you can SEE the audio from the selected input on the record level meters for adjustment or other reasons. It won't prevent you from recording. Set your levels then hit RECORD, let it set itself up and calibrate to the disc, start your source and hit Play or Pause to start recording to the disc.
May 14, 2011 | Pioneer PD-R555RW CD Recorder
Nec dvd+-rw nd-6650a stop burning dvds
It's time to replace the defective (and probably warranty-expired) unit.
If your computer is a notebook, not a desktop, it's best to take the computer to a qualified technician, to disassemble your computer, and replace the drive.
Jan 02, 2010 | NEC ND-6650A DVD RW Dual Layer Burner
Sony VAIO VGC-RB42G PC Desktop CD-RW PROBLEM
Use first cleaning disc and see what will happen.
Sep 11, 2009 | Sony VAIO VGC-RB42G PC Desktop
Dvd 740b not reading blank discs to burn on
NO PC stated dang. laptop or desk?
internal DVD drive or external HP solds all 3.
NO OS stated. windows? Windows what>?????
no real DVD partnumber stated only the usless
front bezel number 740.
if yours is marked 2001,, its going to be a big problem. 9 years past HP support.
and all old drive are weak now or scratched optics.
and drives that old were even full of bugs then
(we an link you to 10,000 pages showing that)
why not upgrade it.?
get a new drive and new fresher OS.
windows 10
and a nice new blu-ray burner.
and move on.
or if this rig (PC)
is 2001 why not go to GOODWILL
and buy a 2010 PC< for like $25
and i bet it works 10x better.
Mar 18, 2017 | HP dvd740i DVD±RW Dual Layer Burner
DVD/CD drive burns, spins, won't read DVDs or CDs
CD and DVD use different lasers. You appear to have a bad or out of adjustment laser. Replace the drive.
Mar 01, 2017 | Sony Computers & Internet
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
CD Player
You're probably right to suspect the motor, since its not spinning, and the lens is clean. I recently had a "no disc" error that was fixed by general mechanic maintnance- taking apart the lens mechanism, cleaning, oiling and putting back together. If youre lucky it could also be your problem, and it should be a minimum repair fee. Good luck
Mar 13, 2006 | Panasonic SC-AK630 CD Shelf System
Pioneer PD-R555RW CD Recorder Logo
222 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
