Zenith ZHX-313 DVD/Video Player
Please could you provide unlock code for the above player to convert it to multi-region; Thank you
I also have this model and it took me a long time to find the solution. It turns out this model is actually an LG.
If you use the instructions for an lg-6000, it worked for me.
Here is a thread I found on another site:
I found a website (http://lgregionfree.tripod.com/) that has a different CD image for LG 6000 series players. I tried that and it works, my player is now set to region 0 and has played region 1, 2 and 4 discs.
Here is the process:
1) Download http://lgregionfree.tripod.com/6000.zip
2) Extract the ZIP file, which contains a Readme file and a directory named RMTM0000
3) Using a CD burning program, burn the RMTM0000 directory to a CDR, making sure to use the ISO9660 file system instead of the default Joliet. Finalize the disc.
3) Turn on the player and insert the disc. The Region Test Menu screen should appear.
4) On the remote, press your desired region (or 0 for regionfree), then press Enter then Pause.
5) Eject the CDR and turn the player off.
6) Turn the player back on and enjoy.
NOTES:
a) I did not need to wait a minute between region selection and pause.
b) On some players this hack causes the buttons on the player itself (not the remote) to stop working. I can confirm that on the XBV443 the player buttons continue to work.
Posted on Mar 16, 2008
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
Jan 20, 2016 | Mitsubishi DD-6030 DVD Player
DVD drawer will not open on Zenith ZHX-313....help???
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Zenith ZHX-313 System
I need a manual for a Zenith ZHX-313
There's a full manual at:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/ZHX-313-_E
It's in .pdf format so you can even download to your computer for future use.
May 01, 2009 | Zenith ZHX-313 System
Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Feb 28, 2009 | Philips Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
DVD player zone
u need region free dvd player buy one off ebay cheap ok
Oct 11, 2008 | Zenith ZHX-313 System
Region codes
dvd players are suitable for all regions but the pins may vary region to region
May 13, 2008 | Sharp DV-NC200
How can I unlock my dvd player to play American dvds please?
I think it is against the law for shops in the UK to sell multi-region DVD players. I could not find a hack for this player that worked.
It is possible to convert it on your PC and burn it as a region free Disc.
May 05, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Multi region dvd unlocker
This can only be done on some dvd players unfortunatly. They are locked to regions because of the video format types that vary from country to country.
Mar 07, 2008 | Yamada DVD-5520 DVD Player
Televison & Video Logo
440 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
