Dvd player/video cassette recorder
I have an INSIGNIA DVD PLAYER/VIDEO CASSETTE RECORDER, MODEL # IS-DVD040924 for some reason it will only play store bought and store rental discs. I can not get it to play my home made DVD+R and DVD+RW discs is there some way to to fix this problem.....please tell me there is
  • heliop100 Feb 26, 2008
    toshiba sd-6980, need change from region 1 to 4
  • Anonymous Apr 14, 2008
    I have a Panasonic DVD Player/Video Cassette Recorder. Model No.NV-VP 60 Series.It will only play store bought (ie professional) video casettes.
    Following the same steps trying to play home recorded videos, DVD sign appears on screen and I cannot get rid of this sign.
    Could you advise what to do.
    Sniper:
  • 67 Answers
Assuming your dvd player supports your dvd+r format. You might need to make your dvd player multi-region or remove the region setting all together.
this website have unlock codes for dvd players
http://www.dvdexploder.com/
Those cheap made in china $35 dvd players have no region setting and will play virtually anything.
Posted on Feb 24, 2008
Why does my dvd only play lack and white
Maybe a fault in the dvd player, connect another one to the tv to see which is at fault
Oct 12, 2014 | Insignia IS-DVD040924 DVD Player/VCR
How do i get my TV to play thru the surround sound of the unit ?
If your TV has a headphone mini jack output ....you need a mini jack to double phono lead ....ask at any decent tech shop.
May 11, 2014 | Insignia IS-DVD040924 DVD Player/VCR
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
How do I record a vhs onto a dvd on the combo?
I have researched the manual for this particular device and you will not be able to convert/record VHS tapes to DVD discs. You can however record content from a DVD to VHS tape as this model only has a readable disc player not a DVD burner. Sorry, but you may want to research DVD recorders that also have VHS playback.
May 02, 2011 | Insignia IS-DVD040924 DVD Player/VCR
Can another Insignia DVD Recorder be used to finalize DVD's recorded on another Insignia DVD Recorder?
Unless the Insignia recorders are both IDENTICAL models, same year of manufacture, and have the exact same firmware versions, you CANNOT finalise a disc in one unit that was recorded on another.
Mar 06, 2011 | Insignia IS-DVD040924 DVD Player/VCR
I need the code for a insignia vcr/dvd combo so that i can use the vcr to record off of my cable box
I would recommend using your cable box remote control's scan feature to locate a code for your Insignia player. If you're unsuccessful, you can request tech support at InsigniaProducts.com.
Mar 01, 2010 | Insignia IS-DVD040924 DVD Player/VCR
Sanyo DVD Player & Video Cassette Recorder - DVD-7200
dvd does not play but video cassette does...fixable???????
Apr 16, 2008 | Sanyo DVW-7200 DVD/VCR
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
Electro Med Services...
