Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer does not agitate
Hi my washer model is frigidaire fex831.
The washer fills but will not agitate. It does fill and it definately spins. It does not agitate in any mode. In fact the only thing getting agitated is me! Ha ha!
I wonder if you could diagnose this.
Thank you,
Jamie Hershberger
  • 1 more comment
  • oliver404 Apr 01, 2008
    We have the same problem. The tub fills but does not agitate or spin. You can't look in to be sure because the top locks, but there is no sign of movement inside. Any sloutions are appreciated
  • dkorsey Jul 19, 2008
    Same problem - washer won't agitate, but will drain and spin. It doesn't try to agitate, just fills and stops. If you move the dial to the end of the rinse cycle it will start to drain and then spin, but no agitation. We don't know if it is something to do with the timer, or if there is a problem with the motor, or transmission.
  • Ron Coons
    Ron Coons May 11, 2010
    does it sound as if its trying to agitate????motor turnig and tub staying idle?adn although water is draining, it it actually spinning???
  • 943 Answers
Hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Posted on Oct 01, 2008
Im having the same issue, my washer fills ill open the lid when it starts to adjitate i can see it trying to go but it doesnt, when its done with the timer it drain then spins just fine. every 3 to 6 months i noticed i have to replace the thing that makes the washer adjitate, i think is called a adjitater coupling? is there something else wrong with my washer?
Posted on Jan 22, 2010
I have a frigidaire heavy duty extra large capacity 2 speed combination 3/4 horsepower.washer dryer. The washer fills,drains and spins. It does Not agitate. I can spin the tub counter clockwise. The thingy...
Hello Marjorie, thank you for your post!
From the information you have provided water will fill, drain and spin but your Frigidaire washer is not agitating. This could be a problem with your motor, belt, or pulley. Locating the problem is not a simple DIY job and I would suggest seeking assistance from a professional. They have the appropriate tools needed to disassemble your washer and prevent any future issues. I hope this information is helpful to some degree. -Matt
Mar 10, 2015 | Frigidaire Washing Machines
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Frigidaire washer spins but won't agitate
when you try to spin the Agitator dose it spin freely both ways if so the DOG EARs are stripped and need replacing Take cap off top off agitator to access the bolt holding the n in place and the Agitator off
Oct 22, 2017 | Frigidaire Washing Machines
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Jun 10, 2008 | Washing Machines
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
2,194 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
