Question about Whirlpool GH5184XPQ Microwave Oven
Microwave troubleshooting my microwave dosen't heat up.f3h code comes up when i hit one of the cook setting
  • mrv14 Apr 22, 2008
    I am having the same problem. My wife put in a microwave popcorn bag, and something happend during the cycle. Since then, when we run the microwave, nothing gets heated. If you use any of the settings that require the humidity sensor, the microwave shuts off and displays "F3H" on the screen. Anyone know how to fix this?
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Posted on Apr 22, 2008
  • shellseek254
    shellseek254 Jan 10, 2012
    AWESOME!!! THANK YOU!!! I was making popcorn while my daughter was visiting this past week and it showed that error. I chatted with Whirlpool - and - after giving her a BUNCH of information so that she could find someone locally to come and fix it she comes back on and says "she's having 'issues' with her system" and gives me a 4,000 character link to find my own local tech. I got online to help myself and found a local company with a $56.00 minimum charge just to come to your house. I started searching around online a bit more and found this site and your suggestion...tried it...and right now I'm eating some freshly popped popcorn!!!!! THANKS SO MUCH!!! Awesome!!!!!
  • David LeRoy
    David LeRoy Dec 27, 2013
    This works for me after much mumbo jumbo from others... pull the plug and wait and put it back in taa daa! My mac and cheese is hot (and its not on my diet so I thought first a higher power was sending me a message but no it was F3H) Thanks muchly from my credit card... David
My microwave displays F7 code when i hit one of the cook setting
Rock
Posted on Mar 06, 2008
  • tdybair56 Feb 23, 2011
    check the micro switch in the middle, or your door is loose and not making good contact with the micro switches, to test push on the middle of handle then cook if comes on again it is a switch issue
Microwave - Kitchen Aid KHHS179LSS4 ERROR CODE -
Hello there Jerry
Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps
However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok
Best regards Mike
Jan 23, 2012 | Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Oven is not heating or cooking in microwave setting, but does heat in convection setting. Manual does not give enough input for troubleshooting. Is it time to call a repair person, or is this fixable on my...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 21, 2011 | GE Advantium 120 Convection/Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Won't heat or cook. Has power, light and clock work, Fan comes on when you push cook button but the carousel doesn't turn and it doesn't cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jhfjk
Jun 29, 2010 | GE Countertop Microwave Oven
F3H message; microwave not heating
heatman101
hgsshg
May 08, 2010 | Whirlpool Accuwave Microwave Oven
When trying to popcornn the sense goes off and F3H comes on
F3H means you have a failing humidity sensor, but the first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can usually download it here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2009 | Microwave Ovens
Microwave suddenly stopped working
Code F3 indicates an open / defective thermistor / temperature sensor. The first suspects when a microwave is not heating would be the door switches, bad connections on the magnetron terminal or bad connections on the control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 25, 2007 | Kenmore 61652 Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
1,711 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
