Ghost image on sony lcd 5 years old
I have a sony KF-50XBR800 lcd projection tv with a ghost image problem
mostly when words or the menu is on I have tryed everything that the image revision has to offer in the menu area
please help
  • 4 more comments
  • Anonymous Apr 26, 2008
    Did the V pos D Tweak. Works great! I press mute, then enter. All is ok. However when I restart the TV. Ghosting is back! I changed 30 ~ 31. But after a few minutes - turn on the TV. And it always goes back to 30!!! I did the tweak 10 times or more. always works!, but does not appear to save! (I do not press the mute and enter botton at the same time). Is there some knid of auto-correct feature I have to turn off or something? Any help would be Great. As a note: I am in Japan and my TV is called KL-50DX700 it seems to be similar to KP-60ws500. anyway, Sony service came and said I needed to change my LCD block etc... $700.00 or more they said! I started looking for a solution and found this tweak into the SM. Great! works great! Picture is fantastic again! But, please any help on permently saving!!!??? I would be very greatful!
  • alpineslider Jun 04, 2008
    I too have the KF-50XBR800 and the ghosting problem. None of the image revision settings seem to fully correct the issue. Auto and "3" seem to be the best, but I can't make any changes to the V position as the other respondent mentions due to my source input being HD. Anyone else had success correcting the ghosting
  • bmajornow Jan 31, 2009
    Same Sony TV, same problem. Auto works best but still there. 1-4 are worse. What is the "V pos" tweak?
  • kostia Jan 31, 2009
    Same problem. Also 5 years old...
  • Anonymous Feb 27, 2009
    I have the same problem, %0" screen, 5 years old, XBR
  • mengle23 Mar 16, 2009
    how can this be repaired without replacing the optics block?? I have a 50" sony lcd projection tv. model # KF-50we610
  • 3 Answers
Just getting back-the V pos tweak works! Just be exact in the proceduere.
Posted on Aug 24, 2010
    Champion:
  • 208 Answers
This problem is a defect in the optics block. There is however an adjusment procedure to correct this problem. Please send me and email to misssiontracetv@msn.com and I will send you back the detailed alignment process on Monday.
Posted on Feb 24, 2008
Where is the lamp located oa sony lcd projection tv model kf-50xbr800
the lamps at right side a front of TV.(look like 2 speaker).It,s snap on.
Nov 06, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
I have a sony xbr lcd projection tv . it goes on and off all the time . like every two min . and the standby light comes on. model KF-50XBR800
Its symptom of weak lamp that reaches to end of its working hours life span. If lamp has not been replaced in last 2-3 years then replace it to fix tv problem.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Jul 16, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
I have a sony kf-50xbr800 that is 6 years old and i am getting a blurred image/ghost image that I can't correct. Changing the image revision setting to either auto or 3 helps a little but does not solve...
The image revision setting is designed to compensate for aging transistors on the optical block assembly.If adjusting it does not completely correct it you will have to replace the optical block.
Nov 03, 2009 | Sony Televison & Video
Red ghosting on images that are not closeup
1. Power off -- let bulb cool.
2. Display - 5 - VOL+ - Power (in quick sequence) to display service menu.
3. Go into the user menu and set auto revision back to auto.
4. Put an image on the screen that shows the problem. I always found the edges of a 4:3 aspect ratio signal displayed the ghosting very well on my set.
5. Use 2 to scroll through the categories to find D GM TG
6. Use 1 to scroll through items in D GM TG to find V POS D
7. Write down current value.
9. Use 3 and 6 to change the value to minimize the ghosting. You should only need to move it up or down a value or two.
10. Press Mute - Enter to save the changes.
11. Power off and let the bulb cool.
Jun 25, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony KF-50XBR800 lcd tv
Can you post a picture of the screen with the ghosting so i can see exactly what you're referring too?
Feb 23, 2008 | Televison & Video
Sony tv will not stay on
unplug the unit for a couple of minute and plug it back in...if it still wont stay on get a repairman
Jan 23, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Televison & Video Logo
1,534 people viewed this question
Top Televison & Video Experts
Electro Med Services...
