Sony KDP-65WS550 flashes when you try to turn it on
I've been reading about the flashing light when I try to turn turn on my Sony KDP-65WS550. I noticed that when i hit the power button on the front to turn it on, the light will flash red once for the attempt and THEN flash the number of blinks for the code. I'm getting 10 total flashes when I first hit the button and then after a slight pause then it will flash 9 times. It will continue to repeat the pause and 9 flashes as long as I let it. I have been able to get my TV to finally come on if I hit the power button enough. I think my TV may just be dirty, I'm going to try and blow it out with a can of compressed air. Update...didn't do anything. Maost things I've read says a Sony should only flash a max of 8 times. Any ideas?
  • 1 more comment
  • Alex Melnick Feb 26, 2008
    I had the same issue with the 9 flashes. I located D6114 and started to remove the board. Once i got the board out I checked the diode with my multimeter on the diode check position. On a good diode you should see .7 volts (silicon diode) one polarity and OL with the lead polarity switched. I was only getting .55 volts and OL. I went to Radio Shack and got 2 of the 200V 1A diodes for 99 cents. Replaced bad one with new one and put the TV back together again. All works great. I reset my faults back to zero and turned TV on and off about 6 times. I then rechecked faults and had zero. I hope this helps. I have a Sony KDP-65WS550. I used this posting and a few others I found to correct my problem...Thank you all for the help. For future reference the D6166 is a misprint. It should say D6116. You TV should only have one of them, so it's just a matter of which one your model has. Thanks again fixya.
  • civictwincam Apr 29, 2009
    My Sony KDP-65WS550 also does not turn on. It flashes 9 times. I have read and understand that replacing diode D6116 & D6301 on the G-board fixes the problem. The tv cover is off and I am having a hard time locating the G-board and the diode, I do have the expertise to change the parts in quiestion. Can anybody point me in the right direction on where I can locate these little suckers...thanks in advance!!
  • Vista Electronics May 11, 2010
    FYI = DLP is KDF series in Sony line....KDP is CRT rear-proj.
    Repair comments are correct............T.
When I turn my Sony TV on I get 10 flashing lights, the sound comes on for a few seconds ad then goes silent. I get no video at all. I power it up again (with the 10 flashes running) and the audio comes up again and goes silent again, it then starts to flash 5 times over & over again on my sony kdp-65ws550
Posted on Oct 18, 2012
  • 8,617 Answers
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Posted on Feb 23, 2008
  • Sonny Berry
    Sonny Berry Feb 26, 2008
    Glad I could help.
I have a KDP-65WS550 when i turn the power on it shuts off by itself, I've tried all the reccomended fixes and none have worked, the red light is blinking 10 times
Hello Mike
I don't know what else have you done with your TV. Yet, from the number of blinking code, I do understand that its video out board has the trouble. But, before going forward with you I want to know whether you are aware in electronics and have some experience in serivce TVs, and can follow the schematic diagrams, if I send it to you. If you aren't aware in electronics and cannot follow the circuit diagram of this set, there is no use of going forward. If you are confident, inform me. I'm ready to assist you. OK.
Nov 22, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony 65" rear projection KDP 65WS550 has perfect
Go into Setup menu and look for speaker settings, make sure "speakers ON" is selected. If you still have a problem, post makes and models of any connected equipment. Hope this helps
Jun 14, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
I HAVE THE BACK OFF MY KDP-65WS550 SONT BUT I CANNOT DETERMINE WHICH OF THE BOARDS IS THE G BOARD
KDP-65WS550 model does not have any "G Board", below image shows board names and location inside this tv, however, there is "G2 board".
Thanks.
Jan 20, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
When tv is turned on you can only hear the audio and no picture. It shuts off after 10 seconds, IS SONY KDP-65WS550
First try replacing STK ICs (2) of them STK392-560s
Mats has them 1-800-628-1118 Also CK pico fuses they will look like resistors But are Fuses 6amps 7amps will be Yellow or Green.
Oct 05, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
How do I replace the lamp in my 65' sony rear projection TV
Sony KDP-65WS550 is rear projection TV that has 3 picture tubes inside. Let me know what bulb you are asking for help?
It is not DLP TV that has ballast Lamp for back light.
Jul 13, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony KDP-65WS550 65 in. Rear Projection HDTV One day turned on
This can be as simple as poor solder connections at the convergence ICs or defective ICs. If you can solder you can fiz this yourself. Let me know if you wish to attempt the repair and I'll suply additional details and instructions.
Dan
Mar 24, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture is distorted on my Sony Grand WEGA KDP-65WS550 65 in. Rear Projection HDTV Television
Can you paste snap of distorted picture of tv here to understand what kind of distortion is this.
Thank you.
Sep 09, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
KDP-65WS550
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
or try this
Sony Too green,red or blue
Feb 06, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Televison & Video Logo
557 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
