Question about RCA HD50LPW164 50" Rear Projection HDTV
No video problem
When the tv is first turned on I get video and audio then when I shut the tv off and turn it back on I only get audio no video the tv will remain like this for several hours or even a day or so then I can turn it on and the video and audio works again until I turn it off.
  • RWbert Feb 24, 2008
    the chassis number is ATC322M1, I am a tv repair man but this problem has me stumped it seems to be in the power supply
  • RCA Master
  • 8,617 Answers
Wha is the chassis number for your set? It should be located on the rear of your setnext to the model number it will be an ATC number.
Posted on Feb 24, 2008
My Sony STR-DN2010 Shuts off When I turn up volume. Also, the HDMI Out to the TV stopped working.
The unit shutting down when you turn it up sounds like a bad speaker hooked up to it. That is the most likely cause. As far as the hdmi problem, with the receiver turned off, press and hold the power button until it says 'clearing' on the front panel. This will reset the unit. Many times it is just a setting that is messed up. If that doesn't fix the hdmi problem, then there is most likely a problem with the hdmi switching IC which will require that board to be replaced.
Mar 26, 2014 | Sony STR-DN2010
Philips LCD TV Turns Off After Being Turned On
Most LCD TV power problems are simply solved by replacing the power supply board.
Oct 07, 2017 | Audio Players & Recorders
No Audio no video on an Element FLX3710
Bad control board. ~$300. Take TV back to wherever you bought it if still under warranty or Purchase new TV.
Mar 13, 2009 | Element Electronics FLX3711B 37 in. LCD TV
My tv screen is green
there is a code to reset the HDMI video, i think it is--hit Display on the remote, then sleep timer and video statice at the same time, then the number 2, then turn the tv off, after it shuts down all the way, turn it back on, should take care of it
Jan 09, 2009 | JVC HD-61G787 61" Television
Tv shuts off sporadically, and now won't recieve any video signal
Check the solder on the vertical output IC this is a common problem and can cause loss of video while sound remains and often will shut the set down with a vertical deflection error
May 07, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
RCA F36689 with Chassis CTC197CR
HI, MY MAME IS vICTOR FROM COSTA RICA. YOU NEED A TV TECHNICIAN BECAUSE YOU HAVE SOME PROBLEMS WITH THE ELECTRONICS CIRCUITOS INCE. I HAVE THE SAME TV, AND I FIXED 2 MONTH AGO, THE PROBLEM MAY BE IS THE FLYBACK, THE PUSH BUTTON PANEL. DO NOT USE AEROSOL, BECAUSE CAUSE MORE PROBLEMS INCIDE
Aug 12, 2007 | RCA F36685 36" TV
Televison & Video Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
