Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100LW1, belt came off
The washer would not move or spin, so I pulled the back cover off and found the belt had come off the pulley on the tub. But the pulley on the tub is extremely loose and wobbly and looks like it has cut into the tub. Is the cut in the tub a problem and is the pulley supposed to be that loose?
  • 7 more comments
  • HRNjr Feb 26, 2008
    Do I need to be looking for something else that might have caused the pulley to do this, or is this a common problem? The pulley will rotate about 2-3" around without turning the tub, thats how bad it is worn out! I also checked the shaft that the pulley is mounted on and there is not any play in it at all! The cut is all the through in some areas. It looks like it was about 1/4" to 1/2" thick. It was caused by the pulley rubbing against it. I have 2 cuts in the top of the tub about 2"-3" long and all the way through about the width of a small pocket screwdriver in a couple of places! Will the tub leak? Thanks for all the help!
  • bliu Mar 03, 2008
    We have the same problem with our washer. I took a look inside and the belt didn't come off, but is cutting into the back of the tub also. I was wondering, why does the wheel at the back of the tub not have a lip/ledge to prevent the belt from moving? How does the belt stay in one position for so long if so? Does this mean a new belt would solve the problem, or might ibe be something more? I would assume a tighter belt would not move/shift.
  • Sybil Owens
    Sybil Owens Mar 25, 2008
    I have Kenmore Elite He3 (same as whirlpool duet). I have replaced pulley 3 times since last year and the belt twice. My fear is the rear bearing as someone mentioned.
    Is this a hard undertaking?
    Any info would be great. I am band aiding it again, but will investigate that rear bearing job.
  • Anonymous May 03, 2008
    I've had the same problem with my Kenmore - replaced the drive pulley
    and it seemed to be fine for about 6 months and it's doing the same thing again... The bolt that's attaching the pulley to the drum seems to be
    cutting into the pulley as well.
  • tupperware Jul 01, 2008
    The belt came off my Whirlpool Duet GHW9100LW1. 2 months out of the 5 yr. warranty on the drive pully/belt system. The best I could get out of the manufacturer was 50% off of the parts. Big deal. They charged me $46.44 for the pully and belt. Shopping online, I found them for $56.00. Almost a thousand bucks for a machine that broke just over 5 yrs. If I didn't do the job myself, I'm thinking probably, a couple hund to have someone come and do it.I grabbed my 24mm socket and my battery impact and tightendup the nut it better hold. If it does not, I will surely make sure it grinds through the tub on the 9th year and they will have to come and replace the assy. under the 10 yr part of the warranty. My next machine will be a Kenmore for sure. They have been used by my family over 30 yrs. at least. My last one worked over 20 yrs. Just didn't look pretty enough for my wife. (Things we do for sex).
  • sirkey777 Aug 26, 2008
    I had same problem at 4 yrs. The pulley is soft metal-- probably aluminum and it wears against the shaft that it turns against to move the basket. Basically it rounds out and begins to wobble which causes belt wear and cuts in the plastic tub. I bought a new belt, pulley, and nut-- replaced them myself. Got 11 months out of them and now same problem just occured. I wonder if JB weld would hold the pulley. I doubt it. I will never buy a whirlpool again-- parts are made to cheaply.
  • max0124 Aug 29, 2008
    Wow, lot's of postings! I've had my Whilpool duet for 4 years and am now into my 3rd pulley...and as a result my third belt. Don't know why they don't make the pulley out of something that will last...
  • Reidman Dec 15, 2008
    Glad I found this. Another Duet owner here. I love this machine but have exact same problem, wobbly tub pulley. Happened just outside of 5yr warranty as well, guess they knew something we didn't..ha ha. I will try rubber washer fix and tightening lock nut.
  • gr8turf Dec 16, 2008
    Same problem, pulley came loose on shaft and needs to be replaced.
I had the same problem and being a procrastinator, I waited until the belt came off before launching a full scale investigation into the knocking noise it had been making for about a year. Here is what I found and below that is my no guarantees fix.....
I removed the nut and pulled the tub pulley off. I noticed the tub shaft has a "shoulder bolt" and the pulley could not be tightened onto the shoulder bolt with enough squeeze to keep the tub pulley from wobbling. Tolerance issue... maybe? I decided to measure the keyed tub shaft with calipers and found the thickest part of the shaft to be 1" ish. The Shaft is part of the tub bearing assembly (from my observation) and the tub shaft is part of the tub bearing which measured 1 1/4" diameter. I found a washer that was 1" inside diameter and 1 1/4" outside diameter and placed it over the tub shaft behind the tub pulley. I tightened the nut snugly and reinstalled the belt. Ahhhhh, quiet operation and no more wobble. I will let you know if it causes another problem but from what I can tell.... replacing the tub pulley with another of the same dimensions will not work.
you don't need a very thick washer(my washer is too thick (.1"ish) so I will replace it soon(yeah right) with 1/32" or maybe 1/16"...I used rubber but I think steel or brass or what ever would probably work too.
Purists will tell you that the lock nut should be replaced, or if you don't use the permanent thread locker you could use loctite.
Hope that helps.
Posted on Oct 02, 2008
  • wish I new Oct 02, 2008
    if you want to order it online go to mcmaster carr
    see part number 95606A280. This is sold in packs of only need 1.
Had same problem, and couldn't wait for ordered parts to come, so adapted the short-term solution from "wish I knew"... Used a #18 O-ring in place of the 1" x 1.25" washer. The O-rings came in pack of 10 from Lowe's for $2. Ideally, would have gotten next size up, because #18 O-rings are 15/16" ID x 1-3/16" OD, and went slightly egg-shaped... but this is a very short-term solution to get us washed and ready for Christmas travel. Seems to be working fine as a stop gap until we can get the new pulley in.
Posted on Dec 19, 2009
  • Whirlpool Master
  • 2,651 Answers
No not suppused to be loose at all. repalce the pulley and pulley nut.cut in tub not a prob, it pretty thick plastic back there, def get a socket to fit that nut though cut my self plenty trying to use pliers or adjustable wrench. socket way to go
Posted on Feb 24, 2008
  • Ron Coons
    Ron Coons Feb 27, 2008
    if you have a problem past the pulley and belt, its with the inner tub(thats the shaft your pulley if attached to) and rear bearing(which is part of rear tub assy). real big job if needs doing, if you can get away with just replacing pulley(and pulley nut)and belt, go for it(remember to wind new belt on pulley like a bike chain, its tight but it will go!
Code LE on wm2277hb washer
I would pull the back panel off, and do a general inspection. When moved, things can get moved out of place by bumps and bouncing and may be apparent by inspection. Most front loaders use either a variable diameter pulley or a gearbox to change the drum rotation speed from slosh to spin. Take a look at the belt that on the pulley on the drum 'axle' and see if there is an apparent mechanism to 'shift into hi gear'. The code is just reporting that it could not spin. A visible inspection may reveal the cause.
Mar 15, 2014 | LG WM-2277HW Front Load Washer
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
My washer, A612S, does everything correctly but SPIN in the spin cycles. Both belts underneath are fine. The motor pulley spin fine when in the spin cycle, but the belt doesn't. When I turn it off...
the brake it the drum directly above the transmission pulley it is not intergrated into the trans.
in my almost 30 years of repairs in that old and very reliable machine i would find where a article of clothing and floated over the inner tub and has wedged itsefl between the inner and outer tub, their is enough clerance between the tub and tub cover where you could get finger into it and run it around the tub and feel if a piece of clothing is caught. if that isnt the problem then the tub bearing is ceased up and would require repalcing it and the tub seal
Jul 18, 2011 | Maytag Washing Machines
I think a overloaded the washer and it wouldnt spin.
Frigidaire washer will not take a overloaded tub without causing belt problems.
Unplug the washer.
Remove the 2 screws on the very bottom of the front washer panel.
Slide the front panel down slightly and remove it from the cabinet.
Inspect the belt around the motor pulley and transmission.
If it is worn at all it needs replacing.
You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
Keep your hands,fingers and tools away from all moving parts.
Jan 24, 2010 | Frigidaire FGX831F Top Load Stacked Washer...
An off balanced load doesn't spin right and washer jumps across the floor. Is there a belt that controls this problem?
no the belt if you have one alot of newer washers do not have belts, but if yours does, the belt moves a pulley witch moves your tub, could be a spring , shock or strut . make sure the washer is leveled. (that it doesnt rock back and forth)
Sep 19, 2009 | Maytag Washing Machines
Maytag washer
sounds like you're suffering from the pump belt either stretched due to overload and overheating the belt, or the belt is off the pulley.
You can remove the front cover by removing two screws near the bottom of the front panel. Tip the bottom of the front panel outward and then disengage the upper clips as you pull forward. This exposes the pump, motor and you can reach underneath to the pulley and the belt. The motor spring holds the tension on the belt. If the belt is damaged, replace. Check the pump to make sure nothing got sucked inside... Maytag's pump are opaque plastic so you can see inside without removing the hoses... This is usually the reason for a tub that won't spin or drain... Good luck let me know.
Jan 19, 2009 | Frigidaire FWS833A Top Load Washer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Amana NAV2330 Wont Agitate or Spin
i would assume that perhaps you did not wind hte belt correctly arround the legs of the pump and therefore are not putting the correct tension on hte pulley(remember to hook spring back up to tension idler?)
Dec 08, 2008 | Roper RAS8445KQ Top Load Washer
Loud Clicking noise only for the first 30-40 seconds of spin cycle.
You may have something caught in the pump impeller. I have found nails, screws, drill bits, paper clips and other small items that some how make their way past the wash tub and into the drain line. I would inspect the drain pump. Remove as much water as you can. Using a wet/dry shop vac to pull water through the drain hose is the best way to drain all residual water from the pump and drain lines. Remove the inlet line first and inspect the pump impeller. Chances are, you have something stuck causing the impeller to rub against it. If this has gone on too long, you may have some damage to the pump. I hope this is helpful to you.
Jul 05, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,820 people viewed this question
Dan Webster
Dan Webster
Sal De
