Question about Mitsubishi VS-8087 80" Rear Projection Television
Mistubishi 6043 A
Horizontal lines throughout screen for all inputs. All cables changed, no resolution. WHat's next?
  • 5 more comments
  • Lezlie Russo Feb 23, 2008
    This was taken from a frozen screen, but the lines actually move.
  • Lezlie Russo Feb 24, 2008
    How expensive is do you think that might be? We have an old Mitsubishi 40" in our garage that no longer works, any chance any of the parts might be salvagable from it.
    The other is a VS405R
    Thank you for your help. We will give that a shot. We don't really want to replace our current TV, so if this works, we will be most appreciative. Have a great night.
    Well, the boards look entirely different on each. The 60" looks like one huge board, but the 40" has 3 separate boards. What do you think the chances are of finding a used replacement board, and if so, what do you think it would cost? Thanks for your help.
  • Lezlie Russo Feb 25, 2008
    DO you know which IC may be causing this. I contacted PTS and they told me that if it is one of 2 IC's,
    IC700& IC2V00. they could not repair it.
  • Mitsubishi Master
  • 8,617 Answers
Is there anyway you can post a picture of the lines on your screen?
Posted on Feb 23, 2008
  • 4 more comments
  • Sonny Berry
    Sonny Berry Feb 23, 2008
    If these are black lines across the picture check Capacitor C933 100uf @ 35 volts for being open it is located on the main PC Board.
  • Sonny Berry
    Sonny Berry Feb 24, 2008
    That's a bad IC on the signal board casing that its called line pairing. I will try to locate a used board if you would like. Parts are no longer available for te VZ3 chassis. Let me know if you would like me to see if can locate a used board.
  • Sonny Berry
    Thats a real good possibility what is the model numbe on that set and I will cross reference the models for you.
  • Sonny Berry
    You will have to remove the back cover on the VS405R tv to see if the chassis looks the same as your current set. The405R used 2 different chassis. They were famous for bad yokes killing the sets so the boards should still be good if they are the same as the other set.
  • Sonny Berry
    Thats too bad. The board will probaly run in the neighborhood of 200.00 used compared to about 600 new. You may consider giving PTS a call alot of times they will rebuild the board in question for a reasonable price. They have a toll free number. If you would like to give them a call here is their link.
    http://www.ptscorp.com/
  • Sonny Berry
    Sonny Berry Feb 25, 2008
    Its IC700 is the IC. Its probably no longer available. I can check into a use board.Thats probably your only option if you want to repair the set.
I have a mistubishi tv model wd-65737 with bad picture. I replaced the video chip and color wheel but that didn't work....is it possibly that dmd board?..thx
Hi, can you tell me what you see on the screen? It could be a bad cable. Are you using an HDMI cable or the color cables (RCA cables)?
Jul 28, 2016 | Mitsubishi WD65737 65" DLP TV
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Display flashes horizontal lines
It's not unusual for a monitor to use different circuit paths based on the the display resolution chosen and so, one could have a resolution that is faulty, while another works just fine. Monitors normally just get dim, or power supplies fail, or other more common failures, blank or white dots... etc.; but, should a monitor live long enough without failing in those areas, usually one or more resolutions will fail. Doesn't leave you much of an option, other than a repair shop, if one could be found; but, as long as it works at that or another resolution, and I'd check the other settings and use it if you have something where it can be used. Sorry for the not so good news.
Jul 02, 2017 | AOC I2353PH New
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Input not supported error
The native resolution for the x193w monitor is 1440x900. The monitor will only allow certain resolutions. You may need to create a custom resolution using the nvidia control panel.
Goto:
advanced options display change resolution customize create custom resolution horizontal pixels : 1440 vertical lines 900 refresh I belive is either 75 or 60. Whichever looks better scan type: progressive
Feb 22, 2011 | Acer X193W LCD Monitor
I have a Panasonic Model TC-p42X1 TV hooked up to a Panasonic SC-PT480 Home Theater system by an HDMI cable from HDMI 1 on TV to HDMI on Theater unit. System setup test okay for speaker sound connections...
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Feb 03, 2011 | Panasonic SCPT480 Theater System
Insert game disk and horizontal lines move fast on screen ???????
Sounds like your TV has multiple video inputs. Make sure the TV is set to the right channel or input. I know on ours if I hit the TV-input button on the tv remote I can change from inputs like s-video, video, cable etc and the Wii only displays properly on one of them.
Mar 28, 2009 | Nintendo Wii Console
Faint horizontal lines from top to bottom after an hour of use...
I can tell you right off the bat that is a service issue you will have to take up with sharp. Contact their operational support, they have a quick turnaround with things like that. When you call, they will most likely ask you to take digital pictures of these black lines and have you e-mail the pics to them.
Dec 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
