Question about Jwin JD-VD130 DVD Player
Wrong Disc System says Loading, it then returns with Wrong Disc. The DVD case says NTSC. Whatever that means....
  • 185 Answers
Are you referring to a prerecorded commercially produced DVD?
Discs are Region Coded This means that you will not be able to watch DVDs intended for use in a different country, unless you have a multi region player. .
There are two video standard formats, NTSC which is mostly North America, and PAL which is the rest of the world. Some players will play both, others won't. Some DVD players allow you to select the format.
Posted on Feb 23, 2008
Dvd wont play disc root comes up?
When you load the DVD, instead of the content loading, the word "Root" comes up? This means the content is either corrupted, the disc is dirty, or damaged. In other words, the laser is not able to reach and pick up the magnetic information on the disc. Does this happen with another DVD player? Try doing that first. In the meantime, clean the disc. If the disc can't be read by another DVD player, then the disc is at fault. If another DVD player can load the disc with no problem, the original DVD player you used, may have a dirty lens (what the laser shoots out of), or the laser is not moving at all. If this is the case, the DVD player is broken.
Nov 25, 2014 | Office Equipment & Supplies
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Screen says loading.Then says (no disc)
There are a lot of reasons why that could happen. Sometimes when a DVD player needs to be cleaned it won't read a disk.Sometimes when you try to play a NTSC disk on a PAL DVD player or visa versa it won't play. Region coding could be another issue. And sometime home burned DVDs won't play in certain players.
Mar 03, 2010 | TruTech DV288B3 DVD Player
"No disc" error
This means that the lens of your dvd player is having a hard time reading the discs. It could be dirty. You need to run a disc cleaner to run into your player for like 30 seconds. It it does not solve the problem. You might need to clean the lens manually. Open the casing and unscrew the plastice plate covering the lens. Then get a q tip damped in an alcohol. Gently wipe on the lens' surface and let it dry. Return everything back and play those discs again.
Feb 13, 2010 | Daewoo DVG-8500N DVD Player
Daytek DVK2001S will not read "PAL" DVD.
Yep, your dvd player may be capabile of producing a PAL video signal, but that does not mean it will play DVDs from a different region. If you require that functionality, do some research on the internet to find a player that will play any regon before making a purchase decision.
Mar 20, 2009 | Toshiba 32AF44 32" TV
DVD portable player - protron DVD player model PDV-288
The 4:3 is an aspect ratio the ratio of horizontal to vertical size and the non-HDTV standard; the latter is 16:9.
The PAL and NTSC abbreviations refer to the picture and synchronization standards whereby NTSC is the American standard and the PALs are European. The setting "sp-raw" refers to an unprocessed video format that requires further processing before it can be viewed.
If the disk you have was made for the American market, you should be set to NTSC and the aspect ratio to whatever the disk is specified, most recent disks will be made to conform to HD specifications, but may also  be viewed in "letterbox" form which is a shrunken 16:9 box with pronounced edges around it.
Oct 06, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Wrong region code?
It means that the DVD is formatted for a region other than the one that you are in. if this is a dvd you made yourself, you need to change the region code, otherwise the people who sold you the DVD gave you the wrong kind.
Jan 09, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Jwin JD-VD130 DVD Player Logo
140 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
Raj Patel
S. Gontko
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
