Question about Sanyo DS27820 27" TV
Digital signal conversion
Does this TV..Sanyo Model DS27820...have a digital tuner or will I need a converter after the switch to all digital next year?
If you have cable TV, satellite TV, or FIOS, the coupon eligible converter boxes aren't needed and aren't useful with those services.
They gov't coupon converter boxes are only good for reception with a regular TV antenna or rabbit ears.
According to the specs on, no, this TV does not have a digital tuner. So, if you use a rooftop TV antenna (not satellite dish) or an indoor TV antenna, you WILL need an ATSC to NTSC converter box. You need not wait until next year, however, as most U.S. TV stations are also broadcasting digital (ATSC) now.
Posted on Mar 03, 2008
Will my TV receive digital signals without an external digital converter?
Hi, John.
No your tv is an older standard definition tv with an NTSC tuner..that was the old type tuner for analog stations.
You will need to get an ATSC digital tuner in order to tune in digital broadcasts.
Luckily, you don't have to spend hundreds to get one.
WalMart and several other stores carry inexpensive digital tuner converters that are in the $30-$40 range.
I hope this helps you out on getting stations picked up, as without the converter, your tv would only be good for hooking up a dvd player to it, or for video games.
Good luck tio you, and have a good day.
Jun 06, 2011 | Sanyo DS31520 31" TV
I have a Sylvanis VCR/DVDcombo and a Standard TV.
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Sep 30, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Sanyo tv model it an HD tv?
You can view the specifications here:
Sanyo DS31520
I found no mention of the needed ATSC digital tuner so you need to acquire a converter box to receive broadcast signals after the changeover. Cable and satellite reception are not affected.
I reviewed the available converters and chose the Zinwell ZAT-970.
Jan 14, 2009 | Sanyo DS31520 31" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Nov 07, 2008 | Televison & Video
Digital capable
You will only need the converter box if you use an antenna. If you have a cable tv service, they will do the conversion on their end.
Jul 19, 2008 | Sanyo DS31520 31" TV
Digital or not digital
this tv has no digital tuner built in to it. In order to recieve a digital broadcast the tuner must be atsc compliant. The best solution is to get a converter box to decode digital to analog signal.
Apr 03, 2008 | Televison & Video
HITACHI ULTRASCAN 53FDX01B TV- do I need analog to digital conversion box ?
you do not have a digital tuner if that is what you mean. if you have a cable box you do not need to worry about this stuff but if you want to pick up over the air signals sometime next year you will need some type of hd to sd converter
Mar 19, 2008 | Televison & Video
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Feb 29, 2008 | Sanyo DS31590 31" TV
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Sanyo DS27820 27" TV Logo
235 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
