Posted on Feb 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
Anonymous
Level 2:
  • Expert 231 Answers
  • Posted on Feb 11, 2010
Anonymous
Expert
Level 2:
Answers
231
Questions
Helped
112829
Points
632
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
917.00 transfer roll
The cuase is the HVPS card. Clean it or replace it.
2helpful
IBM Infoprint 1532 giving error code 922.14 -service fuser error
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
1helpful
Error 80-maintenance
80 Scheduled Maintenance
The operator panel displays this message at each
300K page count interval. It is necessary to replace
the fuser assembly, transfer roller, charge roll, and pick
rolls at this interval to maintain the print quality and
reliability of the printer. The parts are available as a
maintenance kit.
Description Part number
Infoprint 1332/1352 Infoprint 1372
115 V Maintenance kit 56P1409 56P1855
220 V Maintenance kit 56P1412 56P1856
100 V Maintenance kit 56P1413 56P1857
I have new Maintenance Kits in stock at this time. You have the option of doing the kit on exchange or outright. Your Part # should be 56p1409 if you are in the US.
Please give me a call for pricing of if you have any other questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
AOL IM: RORYMRP
[email protected]
Fuser error on my ibm infoprint color 1464
The error is Fuser cam position not found. Have you tried reseating the fuser? Does the fuser make any loud sounds? Based on the error message, it could either be the fuser, or the system board.
Infoprint 1612 displays "maintenance" on menu
You can ignore it if you want, but you will likely see a deterioration in print quality soon, and myabe jamming Etc. "Maintenance" is on an internal electronic counter, and lights up when the life of the fuser, transfer roller, P.F. tires, etc are nearing the end of their lives. To ensure trouble free/ uninterupted operation, you should consider calling for service. The maintenance light can only be reset by a technician .
1helpful
IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
1helpful
2answers
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
IBM 1352 Infoprint
It means it's due for a service, normally the consumables ie fuser, pick up rollers, charge and transfer rollers are coming to the end of their life.
IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
1helpful
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
k24674
ADMIN Andrew
ADMIN Andrew
