Question about Acer Aspire 3610 Notebook
Keys The "T" and "Y" key got out and I can't fix it. Can you help me fix it?
  • Acer Master
  • 19,396 Answers
You probably need to replace the keyboard or to check keyboard flat cable connection inside the laptop. Before doing that just try to see if it is a software problem. For example starting a new installation of windows from cd and checking if keys t and y work when you are required to put serial key. If they do not work it is an hardware problem, as above.
regards
Posted on Feb 23, 2008
How do i fix my b, n and m keys that work improperly, periodically?
You can fix your keys by yourself or by going out to an engineer and get it fixed.
If you think you will not damage your keys then try to take them out by yourself., starting from the Key B , insert a pint between b and v and try to pull out the B Key.
Similarly, take out the N and M key and then use a brush to remove the dust particles accumulated in the keyboard.
Further , blow some air on those keys and try to test them and look if they are still working properly.
and them put those key covers backto position.
DO TIP ME IF IT WAS HELPFUL OR LETME KNOW IF YOU HAVE SOME OTHER DOUBT
Feb 02, 2017 | Cars & Trucks
How to fix Yamaha PSR 400 dead keys?
Normally this would be from dirty or broken key contacts.
Apr 19, 2013 | Yamaha YPT400 61 Key Portable Keyboard...
Sticky keys how do i fix it?
Hi Dgr Welcome to fix ya !
The sticky keys are part of Windows Ease of Access Center Accessibility program.
1. The easiest way to enable/disable the sticky keys is to press the "Shift " key five times. This will turn on/turn off the program.
2. The second way is to press the Windows logo key + U at the same time. This will open the Ease of Access Center. Then select the link that reads" Make the keyboard easier to use."
3. Under the section that reads, "Make it easier to type" you have the option to enable the Sticky Keys or a link to Set Up Sticky Keys. Select whether you want to set up the Sticky Keys or just enable them if you have previously set them up. If setting them up for the first time, remember to click "Apply" after making your selections.
Hope this helps. If you need further assistance, just leave a comment at the end of this solution and I'll be glad to help. Thanks for using Fix Ya.
Jul 10, 2011 | Computers & Internet
My hp laptop keypad's key is broken... how do i fix tht??
Hey there , there is this company who sell individual laptop keyboard keys , i got my keys fixed by them few weeks ago,they have great service . Hope it helps you too,
www.laptopkey.com
Apr 22, 2010 | HP Compaq 6720s PC Notebook
Broken "shift" key.
Well you can try and clip it back on, if able, or use a wee bit of hot glue, or replace whole keyboard.
Apr 02, 2010 | Computers & Internet
My letter 'e' is sticky and I have to press extra hard - do the individual keys come out of a laptop Acer 5720 please
Hello, If your laptop keys are sticky and its causing problem typing, you can replace just the one key which is sticky, visit this site
www.laptopkey.com
I got two of my laptop keys fixed by this company and im satisfied by their service, they send all the underneath fixings with the key , so its easy to fix , hope this helps you :)
Jan 05, 2010 | Acer NSK8458AN Keyboard
How to make the screen darker if fn keys don't work?
Hai,
1. Attach the connector lead of the monitor to your laptop
2. So you don't see the display? :D
3. The laptop has an Function key (Fn key next to the windows start key) on the keyboard. Press and hold the key, and hit the F5 or F8 key or that F key which has the monitor icon on it (it is F5 on toshiba and F8 on dell).
4. This should fix it.
5. Sometimes a high resolution to an extended screen can also be a cause of non-display. Just reduce the resolution of your new (additional) monitor to 800X600 and that must fix it.
6. If these two still don't fix, then your next bet is re-installing your display device drivers.
Hope this Helped!
Good luck!!
Aug 26, 2009 | Microsoft Windows Vista Ultimate Edition
Keyboard keys L/G/R acting weird
It sounds like the Windows is registering the "Windows Key" as being in the "Pressed" position. This is the key between control and alt on the left side of the keyboard. Press it a few times and see if that helps. If it does not it sounds like that key or the keyboard may need replacement.
May 20, 2009 | Compaq Presario 700 470024-192 Notebook
My back key, up key and left key stoped working!!!!!!!
YOUR PROBLEM IS NORMAL. YOUR PHONE'S KEYPAD MUST BE USED VERY FREQUENTLY. JUST GO YOUR PHONES SERVICE STATION AND ASK TO CHANGE YOUR PHONES KEY PAD WITH A NEW ONE. IT CAN SOLVE THE PROBLEM.
REGARDS
KETAN PATEL
Feb 04, 2009 | Sony Ericsson Walkman W810i Cellular Phone
The fn key is working,but it wont t4urn off. how do I get it t6 turn off?
Function ket is a toggle key.
press the function key once, enable press again, disble.
Dec 01, 2008 | Averatec 3200 Notebook
Acer Aspire 3610 Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
