Question about Apple iPod MA446LL/A MP3 Player
Apple iPOD 30 MG
I have an iPOD and it works if you plug it in. It says its charging but when you unplug it, it doesn't work and doesn't hold the charge. Does it have a battery to change and how do I change it????
  • 185 Answers
It does sound as though the battery probably needs to be replaced. If you are technically qualified it is possible to do this yourself, but it is not easy. Try another charger before replacing the battery.
Firstly, you need to obtain the correct battery for your particular model. Lock the ipod in the off position.
Secondly, you need to pull the back off the ipod. Never put a screwdriver anywhere near your ipod, you'll scratch it to bits and damage it.
The back can be removed by pushing a credit card into the join and twisting it until the back pulls away from the front, but believe me...this is not easy. Use an old credit card because the edges will get completely chewed. You can use a hard plastic bladed screwdriver or better still you can obtain a tool to help you remove the back.
When the back has been removed, you can carefully remove the battery from its connector. You will need to make sure you do not disturb the hard drive, pull the ribbon connections or anything else or you can kiss your ipod goodbye.
I have replaced a number of these, but I hate doing them because you have to hold your breath and hope it all works after the replacement. If you don't feel confident, ask a professional to replace the battery for you.
Posted on Feb 23, 2008
Ipod model A1136 30 g
Press and hold the top and center buttons at the same time (upwards of 30 seconds), until the screen turns on (assuming it's charged, and also doesn't have water damage).
If that doesn't work, plug it into your computer, and do it again. This time, when the screen comes on, let go of the top button, and it'll place the device in recovery mode.
(look up instructions on how to place the device in recovery mode)
Sep 02, 2012 | Apple iPod MA446LL/A MP3 Player
It's stuck and won't play the songs
  1. First make sure that your iPod’s hold button is of. (This is the little switch at the top left corner).
  2. Move the hold switch to the on position and then move it back to off.
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  4. If this doesn’t work at first, you should repeat the steps.
  5. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
Aug 27, 2010 | Apple iPod nano
IPOD Nano is frozen
This is a video showing you what the above poster wrote out! Hope both solutions are helpful!
Aug 22, 2010 | Apple iPod nano
My iPod turns on but the buttons dont work! They were working just fine then they stopped! How do i fix it?
Try this! http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm Difficulty: Easy Time Required: Less than 1 Minute Here's How:
  1. NOTE: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
    If the hold switch wasn’t the problem do the following:
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  6. If this doesn’t work, you may have a bigger problem, and ought to get more help.
Aug 03, 2010 | Apple iPod nano
My ipod nano keeps frezzing how can you solve the problem?
Hello :
1: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
If the hold switch wasn’t the problem do the following :
2: Move the hold switch to the on position and then move it back to off .
3: Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
4: If this doesn’t work at first, you should repeat the steps .
5: If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
If that didn't help , then you should take your NANO to the service .
good luck .
please rate !
Mar 30, 2010 | Apple iPod nano
My ipod won't charge. keeps saying "please wait. very low battery" what's wrong with it?
I had the same problem. Went to the Apple store and the technician said that the IPOD battery ran down to low (battery level showed red) and the USB port on the computer was not strong enough to recharge it. He used a rechargeable adapter that pluged directly into the wall (adapter cost about $30) and recharged it enough for me to take it home and recharge it on my computer.He said to never let the battery level drop below 5% unless you are going to recharge it using the adapter that pluged into the wall. I bought an IPOD rechargeable travel kit from Target for $20 and used it to recharge my IPOD. My IPOD works fine now. The Technician also said at some point the battery will need to be replaced (in a year or two depends). Will cost about $59 to replace it (don't quote me on the timeframe or price of replacement, this may have been just for my IPOD but thought this would be useful info for someone.
Nov 24, 2009 | Apple iPod MA446LL/A MP3 Player
Does not charge
Hold down the play pause button for 30 seconds to reset the ipod.
Apr 28, 2009 | Apple iPod classic MP3 Player
My 30 gb
Hold down the center and menu buttons at the same time. If that doesn ot work...switch the hold over to hold and back off and try holding the center and menu buttons down again.
Apr 16, 2008 | Apple iPod MA446LL/A MP3 Player
NOw what?!
Hello again Cholo, Well, we?re going into uncharted territory for me since I haven?t had this happen, however, I have found some additional things to try. -Check and make sure the hold switch is off (orange is hidden). -If the battery is completely dead it may take as long as 30 minutes of charging for it to respond. -Let the power drain completely: Disconnect the iPod from all power sources (apple charger, firewire and USB) and let it sit for 24 hours. Please note that you will probably loose all music and anything else stored on the iPod. After 24 hours reconnect it to the power adaptor or your computer and try resetting again. If it still doesn?t work try letting it charge for 30 minutes. If you get it running again Apple recommends you download the latest version of the iPod software updater and update the iPod. If none of this works try the following: -Connect you iPod to another computers working USB port making sure it?s the only USB device plugged into the computer except you mouse and keyboard. Try letting it charge again. -If you?ve been using one source (USB or apple charger) to charge exclusively try the other. -If using a USB cable make sure its the cable that came with your iPod and that it is in good shape. -If you get this far you probably have no choice except to send it Apple for repairs. Let us know how it goes and please don?t forget to rate the posting.
Jan 17, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
320 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
