Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kemore oven door signal
Hi the oven keeps reading door and will not let me broil or bake not sure what model it is
  • 640 Answers
The door switch is faulty or not closing.Without the model the switch may be in different places.where the door closes check to see if theres a button if there is thats the switch.regardless look around the seal of where the door shuts for the switch.When you do find it simply disconnect the wires from the switch (there should be 2) and put them together.this should solve your issue.
Posted on Feb 23, 2008
Kenmore electric range/ovens
Most likely the clock / control or a thermal fuse if your model has one.
Oct 09, 2017 | Kenmore Ovens
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
My oven will not heat up. the orange light turns on but thats all.
I am assuming this is an electric oven? If you have an ohm meter you can verify that the bake or broil element is good by measuring the resistance across the element. If it reads short then the elements are bad. The more expensive problem which usually tends to be the case is the oven controller board. There are to relays that control the high voltage current that is supplied to the elements. When the oven is turned on a signal from the oven controller activates the coil on the relay and closes the contact allowing current to flow to the element. There are two relays, one for broil and the other for bake. Try the oven on broil to see if that element heats up. If it does it could be the bake element, if it doesn't you till need to get a replacement oven controller board. They usually call them timer modules or clock modules. Good luck!
Jul 20, 2011 | Kenmore Ovens
I have a SMEG SE398X-5 wall oven that does not heat up. The light inside & the controls comes on but will not heat up so there is power to the controls & lights but not to the element & fan.
Hi.
If both baking and broiling element do not heath above a certain temperature, then the part to be replaced is the temperature probe, still located inside the oven cavity.
A faulty temperature probe will keep circuit to the heating elements open, affecting both broiling and baking function.
The temperature sensor can be tested removing it from the oven cavity and reading Ohms on the sensor wires. If the circuit is open at room, then the temperature probe must be replaced.
Regards.
Mar 05, 2010 | Ovens
Neither the oven or broil element comes on. No error code appears, any thoughts?
Hi.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
Regards.
Mar 02, 2010 | KitchenAid Ovens
Oven door is open, but F9 now signals, trying to turn on
HI. this F-9 code is signaling a major door mechanism malfunction. the best action is to replace the entire door latch assembly. this will heel the F-9 alert and, fix the problem you are experiencing at this time.
Please rate and, have a great evening:)
Jun 16, 2009 | Amana AOCS3040 Electric Single Oven
My oven will not turn on or off.....the fan is running and the screen is showing F 02
HI, the F-2 is signaling a higher than normal oven temperature. Follow these steps bellow.
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation. If the door lock device is not working properly, replace.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
May 18, 2009 | Whirlpool RBS305PDS Electric Single Oven
Element Question
In most ovens, both elements are used during the warmup phase even when used for baking and after the set-temperature is reached, the lower element keeps it stable.
You should be able to detect which one is not working with your bare hand. Set the baking temperature for 250-300 degrees, leaving the oven door open. Hold your hand at different heights in the oven and you should be able to sense which element is working and which isn't within a couple of minutes.
If you still aren't certain, then try using the broil element only. If it is heating, then it's obviously OK and that would point to the bake (lower) element by default.
A final check could be done with an open door and hovering with your hand over the lower element; no heat = defective.
Mar 03, 2009 | Amana AOES3030SS Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
59 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
