Question about Philips ProScreen 4600 Impact Multimedia Projector
How do I turn the power off (cool down)
Every projector I have used in the past has a soft power down so the projector can use its fan to cool the lamp down. I can not see it on this model. Is there a way of doing this or do I just use the hard power down.
  • Anonymous Apr 01, 2008
    This projector has no cool-down time.
    So you need no soft power down, just turn off...simple and good.
Yeah just hit the switch and it shuts down. there is no soft power down, which tends to lessen the life of the projector. Sorry man
Posted on Jan 06, 2009
The projector lamps always burning out. I think, the cooling system does not work?How does the projector work?
Make sure not to shut down the projector after use. Wait until the fan stops. The fan is to cool down the bulb during and after use. Once the fan stops, then you can shut it down.
Feb 29, 2016 | Office Equipment & Supplies
Tip
Projector Beep Alerts
When a projector beeps on power up you have a couple things to be concerned about. If the projector is hot, the beeps can mean that it needs longer to cool down.
If you have not used the projector for several hours then it is cooled down. When cold, the beep alerts usually mean the blower fan bearing is restricted.
Clean the air filter and blow out the fan housing. You should just blow with your mouth because compressed air may damage your wiring connections.
If the projector is cleaned and you power it back up AND the beeps continue listen to the fan. The fan may need a little air pressure to help it start turning and then once it does the beeps should stop.
on Jun 21, 2010 | Audio Players & Recorders
My acer projector model 1130pa automatically turned off with in one minutes time. and temperature indication in red position. How it solve
It might be a bad bulb, plugged vents, too close to the wall, running on a soft surface; but probably the bulb.
Jan 28, 2015 | Acer Office Equipment & Supplies
My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
resetting procedure.
1. inset the new lamp.
2. power on the projector.
3. Press menu and select OPTION.
4. Press enter button and the select LAMP RUN TIME.
5. Press and hold MENU button for 3 seconds.
6. Lamp reset , power off message will display.
7. power off the projector. this will reset the lamp hour.
Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
I just replaced a power supply, it has one fan instead of 2. Works great but now I get an error message saying it can't find the fan (which I'm no longer using), how do I get rid of the message?
replace the fan. it needs all the fans the projector was designed with to properly cool it down. without all the fans, the lamp will overheat and cause premature lamp and projector failure. the fan has 3 wires- ground, power and sensor. if the fan spins too slow or not at all, the projector will shut down to prevent damage.
so, replace the fan.
Jun 30, 2009 | InFocus LP70+ Multimedia Projector
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
Hitachi projector temp light
This is what your projector's user manual says about a flashing "TEMP" light :
"The cooling fan is not operating. Turn the power OFF and wait approximately 20 minutes. After the main unit has cooled down, please make confirmation that no foreign matter has become caught in the fan, etc. After performing any needed maintenance, turn the power ON again; if the same display is displayed, then please contact a sales store or a service company."
Your user manual is available at the following link :
http://www.hitachi.us/Apps/hitachicom/content.jsp?page=Products/SupportServices/Support/DiscontinuedModels/index.html&level=4&section=Products&parent=DiscontinuedModels&nav=left&path=jsp/hitachi/forhome/DisplayTechnologiesGroup/
May 20, 2008 | Hitachi CP-X275 Multimedia Projector
Mt800 projector
First I would suggest cleaning the filter on the bottom of the unit where the fan inlet is. Over heating can cause many issues with the video controller in the projector, also shortens the life span of the bulb, always let the unit cool down when turning it off (let the fan run when you turn the power of by top button, never unplug and use the power switch on back. until the fan shuts off.)
Nov 24, 2007 | NEC MultiSync MT830 Multimedia Projector
Philips ProScreen 4600 Impact Multimedia Projector Logo
228 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
