Question about Emerson EWF2703 27" TV
Flickering image Hi I bought the tv used but the back input(all of them including the rf) when I connect anything the image flicker like every 3 to 5 seconds, the front input work fine but I want to conect thing over component. Any other explanation let me know and I explain further where I can.
I have a vcr and dvr combination emerson tv a 27 inch and sometimes while playing it will flicker and these horzion lines come in while a program is runing, and then the sound goes way down then comes back up to normal.
can you give me a answer?
Is it my picture tube it is about to go out?
It is close to five years old
Posted on Oct 13, 2008
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Samsung HLR6167 keeps flickering on bright scenes
Try turning off your Energy Saving option. (mine is in Menu --> Setup --> Energy Saving).  See if that helps.
Oct 09, 2009 | Samsung HLN5065W 50" Rear Projection...
There are flickering, rainbow-like color bands running across the screen, especially in the component inputs, not so much using the HDMI input, but still there.
Hi,if your tv is and Lcd rear projection it will be the light engine that needs replacement.Because lcd technology uses 3 chips green,red and blue that create the image and colors.When they start to fail you will get what you are getting color discoloration and rainbows.If your tv is DLp it will be the dmd chips which basically its like the lcd chips but instead of 3 chips its only one that creates the image.Hope this works God bless you!
Oct 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
Panasonic Plasma with flickering image.
how to installation oracle 9i in fedora 8
can u tell me step by step
my email addres praveen_jujare@yahoo.co.in
Feb 10, 2009 | Panasonic TX-32PK2 32" TV
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
AKAI Rear projection TV
Try using different inputs besides the RF input. Connect your PS2 and DVD player using component inputs. With two component inputs, there's no reason in the world not to do this.
Feb 28, 2008 | Akai PT4298HD Rear Projection Television
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Emerson EWF2703 27" TV Logo
298 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
