Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he 4t washer
Hello I have a kenmore front loader and it keeps stoping and flashing f11 and or f dl. Machine stops, F11 flashes, door lock will not disengage.
Originally had DL problem but that went away with changing the door mechanism. Around $75 for that
F11 problem started soon after that. Unplugging did not work, after a while the cancel switch will cancel everything but I have to start a new cycle and wait for the door to unlock while it is going through its startup paces. Clothes can then be removed but are very damp.
  • caboguy Feb 27, 2008
    Page not found
  • 640 Answers
There are some issues that other people have like yours.go here and youll be able to fix your problem.http://www.fixya.com/support/t127103-kenmore_elite_45986_front_load_f11_fault
Posted on Feb 23, 2008
  • 4,889 Answers
F11 means Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
I work with electronic based equipment often and have noted over the years that harness connections on equipment that vibrates moderately tends to loosen their connections over time. I therefore approached this problem with this in mind. I completely tore down the entire unit, carefully checking each and every component as I went. In all, I found nothing out of the ordinary. I therefore took measures often required of electronic equipment at work. I used a pick to pry the metal prongs on the wire harness connections so that they would more tightly contact the control board.
If you remove the tip cover of the washing machine the control board can be found right in the back, center at the top of the machine. Remove the harness connectors one at a time and carefully exercise the connections toward one another to reduce the gap between them. Keep in mind not to tighten to the point that there is not a gap between them. Remember that these must slide over the edge of the board without becoming distorted, bent or broken.
Step #1 of course should be to limit or reduce the vibration of your machine as much as you are able. Make sure the machine (and floor) is level. There have been some good postings about the use of rubber mats that can be purchased from your local stores and placed underneath of the machine feet.
Step #2 would then be to tighten the connections of the wire harness. Disconnect power! Use extreme caution!
Be advised that I would never tell anyone to jump into this if one does not know what they are doing. Failing to work on any type of equipment can be dangerous or even fatal if one is not familiar with Safe Work Practices, such as disconnecting power cords and checking that the power source IS disabled. Find someone you know who does well with this type of work and let him/her perform the task for you. If this isn't possible, call for the technician. Keep yourself safe at all costs. After all, it's only a washing machine. Your life and limb is worth much more than this!
Hope this helps!
Eagle338!
Kemore Elite Front Load washer was flashing F11 and i repeated the drain, spin cycle several times. now flashing dL and F . The door is locked so I am unable to remove wet clothing.
Try lowering the drain hose onto the ground and see if the water comes out. Turn off at the wall and then back on again a few minutes later. See if the door unlocks this time. Most front loaders wont let you open the door if it thinks its still full of water.
Mar 21, 2017 | Washing Machines
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
    The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
    If the washer starts to fill but the drum NEVER moves, your MCU is bad
    If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
    If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
    Thanks
    Aug 19, 2011 | Kenmore Front Load Washer
    I am getting an DL F code on my front loader
    "dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
    Door lid is not closed completely due to interference.
    Wash media buildup is preventing the lock bolt from extending.
    Machine/motor control detects open door lid switch when attempting to lock.
    Machine/motor control cannot determine if door lock is in a locked state.
    Check for lock interference with lid or lock bezel
    Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
    F11 flashing kenmore he washer
    The F11 error code indicates a serial communication failure. This happens when the 2 main control boards are unable to communicate with each other. This is either caused by a loose wiring harness connection or one of the control boards is defective. Good luck and please rate FixYa!
    Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
    I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
    Feb 16, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load - F11 Fault
    I once had located a code combination to push on the control panel to clear the F11 code. I cannot locate that again. Can you please give me the combination to reset the machine?
    Dec 16, 2006 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    85 people viewed this question
    Sal De
    fordexpert
     Brian Main
    Brian Main
