Question about Sony VAIO FRV37 Notebook
No power after cleaning the motherboard
I recently cleaned the dust balls from the inside of my laptop. What I didn't realize was that I still had the battery pack inside the computer. Once I cleaned out the dust balls with the air duster I started it up and everything was working fine until the power cable harness accidentally popped out of it's socket because the ribbon was so short and the power panel was not in a good position. Since I didn't realize the battery pack was still in the computer I went to put the power harness back in it's socket but couldn't do it on the first try and I saw a red light come on to the power panel on the second or third try. Now the computer won't turn on, no lights, no fan, no nothing! I took out the battery pack and just plugged it in to the regular power supply also and nothing happens and tried to reset the computer too and still nothing! Is my motherboard dead or is there another problem that is easily fixable?
  • 1 more comment
  • alilind2002 Feb 24, 2008
    I tried the battery with & w/o the charger and just the charger and still nothing and nothing looks bad, black or smells burnt on the motherboard. I even thought it might be that I burnt out the power harness but I tried that in my other same laptop and it works........so there goes that theory.
  • alilind2002 Feb 26, 2008
    HA! I got it started but it needs a new power cable harness and now there is no video, just a black screen. Any suggestions here?
    Ha! Got it started but it needs a new power cable harness and also I have just a blank black screen, no video. Any suggestions?
  • Sony Master
  • 13,433 Answers
Damn, you got some bad luck there. without actually haveing the laptop in my hands I can't offer much assistance.
Try to turn it on with and without the battery, then with the battery and without the charger. if noting happens after a few trys you can open it up again and look if something smells bad or looks bad (black or otherwice burned)
Of you can take the laptop to a pc repair center for analysis.
Posted on Feb 23, 2008
  • Ekse Feb 24, 2008
    Theres noting more anyone can do remotely, the problem is hardware and I recommend you take the laptop to a pc repair shop for analysis.
Tip
Clean up your computer
Clean your computerI have a dirty secret. I've never cleaned my computer. Sure, I've dusted my monitor, but I haven't taken off the cover or tried to reach the crumbs lurking inside my keyboard.
"Your computer could fry if you don't keep it clean," says Jonathon Millman, chief technology officer for Hooplah Interactive.
Dust clogs the vents behind your computer, which causes your CPU to heat up—and heat is the biggest cause of component failure in computers. Regular cleaning could save you costly maintenance fees down the road.
Keep your computer in tip-top shape by following Millman's guide to a spotless computer system.
PreparationYou'll need:
  • screwdriver
  • can of compressed air (available from computer dealers or office-supply stores)
  • cotton swabs (do not use a cotton ball)
  • rubbing alcohol
  • paper towels or anti-static cloths
  • water
Always turn your computer off before you begin and unplug all the cords.
Step 1: Inside the caseUsing a screwdriver, remove the side of the case that's opposite your motherboard. Touch as little as possible inside the computer, keeping fingers away from cards and cords.
Blow air around all of the components and along the bottom of the case, keeping the nozzle four inches away from the machine. Blow air into the power supply box and into the fan (from the back of the case). Lastly, blow air into the floppy disk and CD drives. Wipe the inside of the cover with a lightly moistened cloth before replacing it.
Millman recommends doing this every three months if your case sits on the floor, if you have pets that shed, or if you smoke. Otherwise, every six to eight months is fine.
Step 2: Outside the caseRun a cotton swab dipped in rubbing alcohol around all of the openings on the back of your case. Give them one swipe with the damp end of the swab and one swipe with the dry end. Do this as often as you clean the inside of your computer.
Step 3: KeyboardTurn the keyboard upside down and gently shake it. Most of the crumbs and dust will fall out. Take a can of compressed air and blow into and around the keys. Next, take a cotton swab and dip it in rubbing alcohol. It should be damp, but not wet. Run the cotton swab around the outside of the keys. Rub the tops of the keys. If you have a laptop, follow the same procedure but take extra care with your machine. Do this monthly.
Spills — If you have kids, you're worried about spills. If it happens, disconnect the keyboard immediately and flip it over. Blot the top with a paper towel, blow compressed air between the keys and leave it to air dry overnight. For laptops, liquid can easily penetrate the hard drive so turn the computer over immediately and leave it in that position until it dries.
Step 4: MouseRub the top and bottom of your mouse with a paper towel dipped in rubbing alcohol. Open the back and remove the ball. Wash the ball with water and let it air dry. To clean inside the mouse, dip a cotton swab in rubbing alcohol and rub all of the components. Scrape hard-to-remove grime with your fingernail. Finally, blow air into the opening. Replace the ball and the cover. Do this monthly.
Step 5: MonitorMoisten a paper towel or a soft, lint-free cloth with water. (You can also buy monitor cleaning products at computer-supply stores.) Don't spray liquid directly onto the screen—spray the cloth instead. Wipe the screen gently to remove dust and fingerprints. Never touch the back of the monitor.
For laptop screens, Millman suggests buying a special cleaning solution available at computer stores. Do this weekly.
Finally, make sure that everything is dry before you plug your computer back in.
on Dec 29, 2009 | Computers & Internet
Laptop not comimg on plus not even lights showing
Open your laptop and clean any dust, remove the inside cmos batery to reset any bios bad settings and restore to default, if none helps then you have a motherboard issue, other thing remove ram and clean the thin connectors with a rubber and reinstall. Tell me if some help.
Oct 18, 2017 | Samsung NP535U3C-A01UK 33.8 cm 13.3inch...
Hp pavillion dv6405us error beep code 3 1 4 3 - what does it mean? how do i fix it?
Sounds like a Phoenix BIOS Beep Code, but the 3beeps-1beep-4beeps-3beeps code doesn't come up,
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N908
[ + Beep codes for Phoenix BIOS (for older PCs) ]
1) Has the inside of the computer ever been cleaned?
2) Clean the gold plated contact pins of the Ram Memory modules, ('Stick'), and reinstall.
2a) Use a pencil eraser to clean the gold plated contacts,
Remove ALL power. Remove the AC adapter (Charger) and Battery.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band on the pencil contact the gold plated contact pins.
Rub up, and down gently on EACH contact pin. (Both sides) Doesn't take much to clean them. They may not look shiny, and bright when you are done, but I assure you they are clean.
Handle the ram memory module by the BODY. The Body is everywhere on the ram memory module except for the gold plated contact pins.
The Body is coated with a see-through protective plastic.
Use air to remove the eraser dust before reinstalling. If you have a can of compressed air for computers available, use it. If not air pressure from your mouth will be sufficient.
http://www.youtube.com/watch?v=f7sRPDmcE9o
1a) The cooling system uses air to cool the hardware components inside your laptop.
If the cooling system is clogged with 'Gunk', and cannot adequately receive the needed air flow, the Processor and graphics chipset will overheat.
['Gunk' = Dust, dirt, hair, lint, carpet deodorizer, food crumbs, etc ]
The Processor and the graphics chipset (G.P.U.) are the two hardware components that give off the most heat.
Having the laptop dirty inside can cause a serious issue also, and especially on the Pavilion dv6000 series of Notebook PC;
The graphics chipset is mounted to the motherboard with a BGA surface mount. Through constant overheating of the graphics chipset, the solder joints (Connections) may partially melt, then re-solidify when the laptop is turned off. (Cools down)
This cause cold solder joints of the graphics chipset to motherboard, and a poor contact of graphics chipset to motherboard.
The problem with the Pavilion dv2000, dv6000, and dv9000 series of Notebook PC's, is inadequate cooling for the graphics chipset.
1) http://www.youtube.com/watch?v=JEpnqhRYGLw
2) Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
3) The integrated circuit, or chipset for graphics; is the graphics chipset, or G.P.U.,
http://en.wikipedia.org/wiki/GPU
4) Video showing an average BGA (Ball Grid Array) Rework Station at work, and showing the Solder Balls, and Copper Pads of a BGA surface mount,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red -
Take a few minutes to view the IR 650 demo video
Regards,
joecoolvette
Sep 18, 2012 | HP Pavilion DV6405US 15.4" Notebook PC PC...
HP s3620f computer. It worked fine after the house was flooded (computer didn't get wet). My mom moved it though from one family members house to another. It sat in her car for at least a week getting...
It may be the power supply or the memory, try cleaning the dust and mud inside.
Then remove the memory and clean it and insert it back again and check
If required just replace power supply and memory and check
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @
www.thebestpcdoctor.com or via 877-407-9229
Please Rate if you find it useful
Oct 11, 2011 | Computers & Internet
Im using sanyo pdg-dsu21b model. right now, my projector has this little white bright spot all over the projection. can anyone please tell me whats the problem with my projector and what is the solution...
Unplug you projector and allow the bulb to cool. Open the area where the projector bulb is located. Check the projector lens for any damage and clean it from dirt's and dust. Same as with the bulb.
Nov 09, 2010 | Sanyo PDGDSU21E DLP Projector
My mouse pad will not move my cursor on my computer
If your mouse is the older ball type hold the mouse level about 12 inches off the pad and move the ball on the underside of the mouse with your finger. If the cursor moves you may need to simply clean any dust from inside the device and clean the ball. Open the open to release the ball. Theres a round plate on the underside around the ball. Turn it to the open position a remove the ball. Clean any dust from inside with canned air or a soft brush. Clean the ball with a small amount of alcohol and let dry completely. Replace ball and plate and you should be ready to go.
If you have an infrared mouse, your mousepad may be too glossy. Dry a pad with a dull finish.
Jan 18, 2010 | Computers & Internet
I am unable to move the mouse anymore or click with the buttons, I have tried turning the access on and off as well as the laptop on and off. I am using a compaq presario cq50
If you have an old style mouse it might need cleaning. Turn it over and see if the case will slide off. There is a ball inside the case. You need to clean out the dust - you can use some canned air to get the dust out.
Dec 16, 2009 | HP Compaq Presario CQ50-110US Laptop
Mouse somtimes sticks
unscrew the ring that holds the ball in place and remove the ball. clean out any lint, or dust, etc on the ball and inside the mouse where the ball sits and rides. once it is clean put the ball back in and replace the ring. that should solve your sticky mouse problem
Oct 25, 2009 | Dell U0636 Mouse
CPU fan fail or speed too low warning message.
For sure you have done something wrong in fixing up, re-check that you havent unplugged the fan aur havent damged the wires aur there jacks.
one possibilty maybe that you have cleaned the material present between fan and processor which is responsible for heat conduction.
Jan 29, 2009 | ASUS A8N-E Motherboard
Sony VAIO FRV37 Notebook Logo
119 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
