Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker I got a kitchenaid side by side refrigerator for couple of years. Now the ice maker doesnt make any ice but all other function is proper. I heared strange noise after I turn on the ice maker switch but no water coming out of the tube. Any hints could I get from you? Thanks, Alex
    President:
  • KitchenAid Master
  • 2,651 Answers
Reach your hand into ice maker assy, is there ice in it and not ejecting??? there are tines that eject the ice, do these move around freely and easily(if so you need a new ice maker they should not turn by hand)
Posted on Feb 24, 2008
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
The ice maker is not functioning?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | KitchenAid KSBS25FK Side by Side...
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
Ice maker quit workingon kitchenaid side by side bowfront
check to make sure yr getting water to inside of ice maker if you are then replace the icemaker you can order them from marcone or allbrands appliance
May 16, 2010 | KitchenAid KSCS25FKSS Side by Side...
Water and light work fine... ice maker doesn't
It sounds like the control valve for the icemaker is not working properly. These valves are easily replaceable. Just follow the incoming water line to the point where it goes into the refrigerator wall. The valve should be at that point. There will be connections for the water, both in and out, and also electrical connections.
Oct 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Ice Maker Isn't Working Anymore
yes the door dispenser and the ice maker have separate valves it could be the ice maker valve isn't working properly could be the motor module is bad on the icemaker its self get a 10 gauge piece of wire about three inches long strip about 3/8 to1/2 in off each end pull the front off the icemaker and you will se a bunch of little holes they will have letters on them put the wires in the holes marked t and h kind of wiggle it side to side and watch the ice maker if it does nothing then replace the motor module on the front of the icemaker (you don't have to buy the whole icemaker you can buy the module separate ) if the ejector blades move then when they get to the bottom pull the wire out wit for it to complete its cycle see if it fills if it doesn't then change now if your ice bucket is in the door that can be a whole different animal reply to me and let me know what you find and if you have the icemaker in the door dont buy anything till we check it out as a mater of fact if you pull the bottom kickplate off there should be a tech sheet in it or in a plastic bag under the fridge
Feb 20, 2008 | KitchenAid KSRP22FNSS Side by Side...
Kitchenaid superba KSRG22FKSS01 Ice cube switch trouble
Since its an indoor ice maker its much harder to diagnose. However the motor is supposed to reverse for crushed/cubed so you can hold the freezer door switch and see if it does. If it doesnt reverse it could be the switch, or it could be a mechanical problem inside the blades (check for broken stationary blades)
Oct 18, 2007 | KitchenAid KSRS25IL Side by Side...
Ice maker not working
Sharon, I've owned a comparable Kitchenaid refrigerator and have had at least six service calls over the past two years due to the ice maker not functioning properly. Gears have been replaced, sensors replaced, the whole ice maker has been replaced, and the problems keep on coming. Just last week the element that pushes the ice through the grater quit working. The only salvation for me has been that I purchased and renewed the extended warranty with Sear on what I had anticipated would have been a quality product. Kitchenaid has been absolutely worthless in responding to my concerns. Typical service charges for these repairs would run $140-$200 without the service contract. Oh yeah, the ice maker also chronically fails to expel the ice into the hopper because it gets jammed in the tray. Good luck!
Jul 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
354 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
