Question about Hunter 33201 Humidifier
No moisture My humidifier is running and the fan is blowing out cool air, but not producing any moisture just air.
  • 1 more comment
  • Anonymous Mar 06, 2008
    I am having the exact same problem. Cool air is all that is coming out. No moisture at all. Should i return it or is there some way to fix it.
  • Anonymous Mar 13, 2009
    My humidifier is only emitting cold air and no moisture.
  • Anonymous Mar 29, 2014
    no water getting to wicking filter to release moisture into air
  • 123 Answers
Is the level of water dropping? If so, the humidifier is working. If you have a cool air humidifier you won't see any steam or anything at all. You will just feel cool air. Watch the water level and see what happens.
Good Luck.
Posted on Apr 18, 2008
I bought a hunter humidfier about 2 years ago and now i am using it for the first time. I took all the plastic off around it and opened up the top to make sure the filters and everything is in place. I...
Hunter carefree humidifiers use a reusable and washable wick this method of humidifying does not produce a fine mist like many centrifugal (cool misting)humidifiers. The fact that it is producing cold air seems to indicate it is working. However it would not hurt to check the water intake for blockages it also a good idea to run these models on high for several mins when starting this ensures that water is being pumped up.
Mar 07, 2011 | Hunter CareFree Plus 33222 Humidifier
Model RCM-832. On/off switch works, blows air but no moisture seems to come out. I left it on for at least one day and the water level in the tank remained the same.
First check humid-stat setting make sure that the room is not above setting. Second check that float(water level) switch is being made. Hope that helps
Feb 08, 2011 | Robitussin Cool Moisture 1 Gal. Humidifier
The fan is loud and the motor is running "hot". Is there a place to oil the fan's motor?
This is a sealed bearing motor so there is no oil ports. You can blow out with compressed air and spray motor shaft with WD-40. Be careful not to spray any lube inside motor. If you can get to them blow out motor cooling ports .this should help motor run cooler and quieter. Hope this helps you. Thanks
Jan 02, 2011 | Essick Air Credenza 696 400 5.2 Gallon...
Air/no moisture
the reason why you might not see the moisture coming out cause it's a cool mist humidifier. to test your humidity in your house you might want to get a humidistat which will letyou know if your getting the humidity in your room or not. now if it's a warm mist you will see it but it's a coolmist so you won't see moisture coming out.
Jul 16, 2009 | Hunter 33201 Humidifier
Does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
May 20, 2009 | Whirlpool AD40U Humidifier
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Where is on/off switch HCM-305T-CST
There is a 0 setting on the fan speed setting knob ...
Dec 20, 2008 | Honeywell : Cool Moisture Humidifier...
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Water on floor around humidifier
I haven't had any problems with my Vicks Cool Mist Humidifier other than the fact that the area surrounding it is slightly wet after operating for a couple of hours....While I understand that I was using this to moisturize the air during a cold, I knew this would happen, because the air in my room is not dry. If the room isn't dry, the mist that it's putting out in to the air has no where to go but surround the humidifier. All I did to stop this was to buy a water proof mat. I suggest you do the same -- Also, in regards to the water smelling -- You should be cleaning out and drying the basin after every use. Water shouldn't smell unless you let it stagnate inside the plastic -- Try running distilled vinegar through the machine for a couple of minutes -- Also, I would use an extension cord and let it run outside so that your house doesnt smell like Vinegar.
Oct 18, 2007 | Vicks Cool Mist V400 Humidifier
Hunter 33201 Humidifier Logo
702 people viewed this question
Top Hunter Humidifiers Experts
Vernon Taylor
ka4iup
ka4iup
mike
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
