Goodmans Amplifier Speakers , Humming, Capacitor wrong way still worked for a year!
Had these speakers for just over a year and they have been working fine until one day after the guarantee period they started to emit a buzzing sound on both channels , i instantly assumed that the capacitors were at fault. I opened up the device only to find one of the output capacitors connected the wrong way round. The Positive leg was connected by a fly wire aswell as to the pcb to the heatsink and the negative leg was on the positive. I tested these points with my multimeter to confirm my finding and it was indeed backwards , but i dont see how it should of worked in the first place. The voltage raised to about 41.2V peaked since it was a 50v 3300uf capacitor.. ive never had no trouble until the guarantee period ended.. i dont want to end up replacing the capacitor only to find it blows up.
I dont get it its well strange, ive never known anything like this .
  • Jonathon summesfield Feb 29, 2008
    Its fixed =].. i overlooked 2 buldging capacitors in the power supply area.. oops. And ive taken ur advice and i have changed the capacitors to 63v and seems to run a bit better now . Unfortunatly both the caps and the diode bridge were backwards , got them sorted now. Cheers.
  • shewes Jul 07, 2008
    I have a Goodman's amplifier which is now about 18 years old. It has never given me any trouble. I have recently moved house and it has been working fine for about a month. I have connected new longer speaker wire to the speakers. All of a sudden, there is a loud humming coming from speakers, even with volume turned down. I have retested with the old speaker wire and also tried different speakers but the same thing occurs - so I assume the amplifier is the problem. I am not competent enough to open the appliance. Any suggestions before a shopping trip?!
  • 1,512 Answers
Hi, wow...caps of that value usually go boom real quick when fitted back to front. I too am amazed it has functioned that long. Just double check that incorrect screen printing on the board has not tricked you. Have you put your multimeter across the bottom of it to actually see constant reverse DC volts(ignoring the board markings for now). then replace the offending items, just check that the voltage they are being run at is at least 2-3 volts less than 50v rating of the cap. alot of gear runs really close these days and the supply caps fail early, we see alot of it here in Australia where our supply is 240v you see it at the socket alot of the time at 250-255v Hard on gear designed originally for 220v. I would sub the caps out with 63 volters anyway to be sure of some longevity. Good luck, I am interested to know how you go. Let me know please.
regards
Graeme
Posted on Feb 29, 2008
Speakers have a crackle in the sound also rear speakers not working
can mean several things. The crackle is subjective and can mean distortion. Distortion most of the time comes out of the amplifier. Could be you have blown a capacitor in the power supply of the amplifier, making it work with quasi half the voltage. There is no need to change the polarity on a speaker, because when one is not working infuse, it won't distort the music. You only could have difficulty with the stereo sound. It could be a bit unclear where the sound is coming from and could sound a little less powerful.Check the speakers on a different amplifier, to hear if I'm right. Only if you switched on sound while the amp was giving full power, you could have blown the speakers, but most of the time they don't give any noise after that.
Jan 16, 2015 | Ranger Communications 1998 1999 2000 Ford...
Philips SPA7351/27 humming sound from all speakers and subwoofer whether they are connected to the computer or ipod.
It is more than 4 years after Ron Maxson posted this question about his speakers humming. I'm guessing he's given up by now and tossed the speakers in the recycle bin at work somewhere.
I found this exact set of speakers in the electronics recycle bin at work. Usually stuff that ends up in the recycle bin has some kind of issue. I will add that I don't know anyone by the name of Ron Maxon at work, so I am pretty sure the ones I found are not his. :-) Before even trying the speakers, I searched Fixya to see what kind of problems they might have. This was the only issue I found on Google or Fixya. I was kind of hoping the set I picked up had the same issue since I haven't seen any other issues or repairs. When I hooked the speakers up to my PC, there was a very loud and irritating buzz/hum/tone that I could hear whether music was playing or not. And the "hum" seemed to match the description Ron gave.
So I have the same set of speakers (Phillips SPA7351/27) with what I beleive is the same issue (constant "hum"). Often times in electronics, when something was working, but now isn't, or is doing something different, it can be due to a bulging capacitor. My parents had an internet modem once that stopped working. A light on the modem indicated there was some error that would need to be serviced, but that's all the info we could get about the error. Inside the wall-wart I discovered a couple of bulging capacitors and replaced them. The error on the modem went away and worked as normal.
In this speaker set, I suspected it was something along the same lines. The way this set of speakers works starts at the AC plug that goes into the wall socket. This AC voltage feeds a step-down transformer that reduces the home AC to an AC voltage closer to around 15V AC. That 15V AC will then feed into a set of diodes that will full-wave rectify the AC signal so that it becomes more like DC (instead of a sine wave, you get something that looks more like camel humps if you see it plotted against time). Then a smoothing capacitor is used to level off the humps so that a closer to DC voltage is created for any following circuitry. The DC voltage plotted should be a constant value through time. The smoothing capacitor is usually pretty big when AC is converted to DC using a transformer/bridge-rectifier circuit. The value is usually around 1000uF. In the case of audio electronics, this smoothing capacitor is usually something like 4700uF and is about half the size of a AA battery (imagine cutting one in half).
When I opened it up, there was a bulging 4700uF 25V capacitor sitting there next to where the transformer connects into the main PCB. I saw that Amazon had the same value capacitor for sale in a set of 10 for $8.99. I'm sure you can pick one up for cheaper on eBay or Digi-Key, but I wanted to get this fixed pretty quick and already have "prime" 2-day shipping. Plus I can use the extra caps for other projects/repairs.
My capacitors came in today so I de-soldered the bulging cap and installed the new one (got some help pushing the new cap in while I soldered from my 4yo son... what a good helper!). I added some thermal paste to the back of the amplifier chip. By the way, the amplifier chip is an STMicroelectronics TDA7379 chip. You can google TDA7379 and find the data sheet which contains circuit examples including how to configure a circuit for 2 stereo speakers and a single speaker.
I finished the part replacement, screwed everything back together, and WOW! What an improvement. The buzz/hum/tone I was hearing is gone. I have a nice set of PC speakers now for probably about $1-$2 worth of parts and part of an afternoon.
If you have the same set of speakers or even a similar set with these symptoms, you might want to open it up and check for bulging capacitors. They are easy to find/replace for cheap if you have a decent soldering iron or know someone who does. Likely the circuitry is very similar. I am including pictures of my teardown and hopefully can show the bulging cap as well as the new one. The bulging cap is the "KONMO" part while the replacement good one is "ChengX" in the pictures.
One thing they always say is to be careful with large capacitors as they sometimes still hold charge. I've never had an issue with them but I always try to be careful not to short the two wires coming off of the capacitors.
Ron if you still have this set laying around somewhere, you might check for this issue and see if it fixes it.
*Sadly my annotations in the photos were removed. I spent a good amount of time highlighting what I wanted to focus on in the pictures and the annotations showed up before I posted them. I don't see them now. Feel free to ask me if you have a question on one of the photos.
This photo shows the circuit board part number which is similar to the speaker set model number.
This photo shows the location of the bad capacitor. I have removed the circuit board from the rear panel of the subwoofer.
Below you can see that the top of the problem cap is not flat but bulging. If you see a bulging cap, it is no longer working. This cap's job is to make sure you get clean DC power to your amplifier circuitry.
The step down transformer is this big heavy thing screwed to the inside back panel of the subwoofer assembly. It takes wall AC and turns it into lower voltage AC on the blue wires that connect to the circuit board next to the faulty capacitor.
Since I removed the circuit board from the back panel, I thought I would show how the holes and screws line up to the back panel. Notice the white spot on the right side. This is thermal paste used to help transfer heat from the amp chip to the metal of the back panel. You can buy some and add more if you want to make sure it transfers heat well. Also notice that I put the screws back in the holes they came out of on teh circuit board and back panel. I had a couple of days to wait for parts and used this system to make sure I remembered where they went.
Here's the side of the new capacitor. It shows the -40 to + 105C rating which matched the capacitor I removed.
This is the other side of the new capacitor showing the 4700uF value and 25V rating.
Below is the old bulging capacitor before I removed it. Take a picture of it before removing so that you can remember which side the strip (negative side) faces. These can only be installed two ways, but it is important to get it correct.
Here is the new capacitor installed. Notice the white stripe (negative side) matches in orientation with the previous photo of the bad capacitor. Also notice how the top is flat.
Here is a picture of the amplifier chip if you are curious about how it connects up to the speakers and other circuitry.
img_20180602_155432732-uoew345wpw3ewzltlqiqwepn-2-57.jpg The "X" on the top of the capacitor is designed to release gasses when a capacitor fails. It lets the gas out in a slow and controlled way so that the capacitor doesn't explode catching your circuit board/speakers/house on fire. When you see a bulging cap, it has let the gas out and no longer works the way it was designed. In the case of these speakers, it was not smoothing out the voltage to the amplifier which caused the "hum".
More info/learning:
Here is a link to the amplifier chip if you are curious of the specs and suggested connections:
http://www.st.com/content/ccc/resource/technical/document/datasheet/fa/38/9a/71/78/45/44/16/CD00000160.pdf/files/CD00000160.pdf/jcr:content/translations/en.CD00000160.pdf
Here's a link that shows the full-wave rectified graph to give you an idea of what the capacitor is doing. It creates the red line in the graph:
https://www.quora.com/Why-do-we-use-capacitor-in-rectifier-circuits
This link also gives some information:
Selection and use of Capacitors Circuit Clinic 2
Notice in this link where the auther writes: "Here the smoothing capacitor is 4700uF 50V because the power supply is that of an Amplifier circuit. If the smoothing is not perfect, humming noise will appear in the speaker." Previously he was describing a 1000uF capacitor and mentions the 4700uF value because of the audio amplifier circuit.
Hope this has been helpful! It was a quick and easy repair.
Jan 30, 2014 | Philips SPA7351 Multimedia Speakers 2.1...
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Polk audion psw250 subwoofer has humming noise
Humming noise on your sound is not due to your speaker but it is come from the amplifier. I've encountered a lot of this problem that is caused by the electrolytic capacitor. If you are a technician first locate for a dry joints on the board and then resolder it using your soldering iron and a high quality soldering lead. Resolder not only the capacitor but also around the output I.C.
If nothing happen then it is coming from your output I.C. sometimes it was leaky/shorted which produces a humming noise but first do the the above mentioned instructions before isolating the defective output i.c.
Jan 03, 2011 | Polk Audio PSW250 Subwoofer
Loud humming noise
this may be result of blown capacitor - have it analyzed by applying strong magnet over the inside speaker , if humming persists, then its not blown capacitor -- the capacitor stores energy, and if that energy is lossed an out in the airwaves, thats the humming effect
Oct 15, 2010 | Cambridge Soundworks BassCube 12 Speaker
Tv works but no sound
Hello Jjwpod hi, to find where the trouble is, you need to place ear near speakers, you should hear a humming sound, adjust the volume up or down, the humming sound also goes up or down, this means your amplifier is working, no hum means trouble in amplifier.
summary:
No hum: trouble in amplifier, speaker connection.
Humming, but no audio: problem before amplification, most likely the Sound IF stage.
Sep 16, 2010 | RCA F27615 27" TV
How would I attach my hi-fi Goodmans Speakers to a LSD TV
Your best bet to improve the bass is to attach the audio output of your HDTV to a stereo unit and amplify the audio with the amplifier. Attaching the speakers to the HDTV will not improve the sound much. Sorry.
Jan 11, 2010 | LG 42LC2D 42 in. LCD HDTV
Yamaha psr-240 lights up but no sound.. no sound from head phones either. Seems to be working with exception of sound out..
try placing your ear on the speakers, adjust the volume control up and down several times, you should hear a humming sound that goes up and down. if not problem with the stage before the amplifier, that is the sound processor. if you dont hear the hum. problem with the amplifier and speakers, including the sound ports or jack. dissassemble the unit. look for loose connections from speakers to amplifier.
Jul 14, 2009 | Yamaha Portable Keyboard with 61...
Left speaker wont work
humming is caused by defective amplifier.either left or right.unless you connector is faulty.try changing the connection cords, first. if not, then call a tech for mano y mano analysis.
May 16, 2009 | Boston Acoustics BA745 Computer Speakers
No sound tv
it can be many reasons
1 some tvs have on the back a internal/external speakers many times the customer unadvertidly move the sw to the expternal position
2 the speakers are deactivated from the man many
3 check if the tv has a his noise coming out from the speakers at full volume if so then the amplifier are good & the same for the power supply if no hissing noise then check dc votege is geting the amplifier if so then the amplifiere is most likly the fail if not then the power supply is at fault
3 check for the output capacitor that most of the amplifiere have in the output is conected directly to the speaker
4 if no capacitor is found then it must be +B & -B in order for the amplifier to work the lack of one of them mus make the amplifier unoperable then define why is not ther & fix the cause
Feb 03, 2009 | Televison & Video
740 people viewed this question
 Grubhead
Grubhead
