Vanguard International Infra Red - Medium Infra-Red Mid-Size Heater Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I convert vanguard VMH26TPA wall heater from propane to natural gas?
Frank Bryant Wetzel
Level 3:
  • Master 456 Answers
  • Posted on Feb 11, 2010
Frank Bryant Wetzel
Master
Level 3:
Answers
456
Questions
0
Helped
121809
Points
1116
You would have to get a conversion kit, which usually
is new orfices and a spring that goes into the gas valve. The kit would probably be cheaper than buying a gas valve and the orfices seperately
I have a model VBWH30LT Vanguard Blue Flame Wall Heater. Can I change it from LPG to natural gas?
Most gas appliances are designed to operate from methane, butane or propane, though suitable alterations have to be made, line pressure, gas jet size, air mixer and so forth as directed by the manufacturer.
Methane or natural gas has a lower calorific value and needs a higher volume of gas to function efficiently...
I am looking at a Vanguard VP20BTB propane heater but I need the dimensions to make sure I can use it. Does anyone know the dimensions?
Can u get right orfis from propane company to fiut heater
You need a conversion kit reg injectors etc . Some models do not convert check with makers first .
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Hello, my name is Jerry I have a vanguard wall heater that is propane but want to use it as a natural gas
Somewhere is an "orifice" that will fix the problem.
This part, if it is accessible, should be near the end of the pipe where the gas is attached to the heater.
Orifices have tiny holes of different sizes depending on the type of gas and pressure used.
Even if you find the orifice and managed to remove it, finding a different one for a different gas may not be easy, or impossible.
Be blessed.
Can I convert a vanguard vp1600tc from propane to natural gas?
I believe yes but you do require a gas fitter to do so. the change requires to change the orifice simple and cheap but the gas fitter may be greedy. Check with your utility company they may even come out and change it for you.
I have a vanguard vn1800e natural gas would like to convert it to propane is this possible
Sorry, but no vent-free gas heating appliances can be converted from one gas type to another. There are no conversion kits available for any vent-free gas heating appliances.
Wish I had better news for you.
2helpful
Pilot light too big, how do we adjust pilot light on a Vanguard KV1800?
There is no adjustment for a Pilot Flame's Length on a Vent-free Gas Appliance. However, if you're using Natural Gas and it's a Natural Gas Heater, the normal length of the pilot flame is 2 to 2 1/2".
If it's a Propane Gas Heater and the pilot flame is as long as previously stated, you probably have a pressure problem from your tank. Contact your Propane provider to have them check the pressure on their tank regulator.
Change from natural gas to propane
You could do it but it would be very expensive. You would need to change the ODS pilot and the gas valve itself. I am not sure even then it would work correctly. These are not conversion ready.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Vanguard Heating & Cooling Experts
Paul Carew
john h
Jay Finke
Jay Finke
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
