Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Gaggia evolution- water doesnt flow through the brewer
The problem appeared when I tried to descale the machine using gaggia's descaling solution. Before that the machine worked fine. Now I have water throu steamer, I hear the pumper, but the water doesnt flow! When it has warmed the water in the boiler and I press the button, I do not hear the same loud from the pump, but a smoother one and of course the water cannot flow. Any suggestion?
  • kanga1953 Mar 02, 2008
    I too have the same problem. I descaled the machine. The pump sounds like it is working but nothing is coming out!
  • Anonymous Apr 01, 2014
    water flows out at a trickle rate. I've tried without installing the portafilter and I can see a slow trickle which doesn't register any pressure on the pressure gauge.
I descaled my Coffee Deluxe machine and am now having a water flow problem. Water comes out the centre hole in the filter holder just fine but when I put the filter back on, the holding screw blocks the flow and nothing comes out. Is the water only supposed to flow through the center hole or does it pour through the four surrounding holes on the filter holder too? I can't seem to figure out how to remove it. I can remove the two hex bolts on either side but it hasn't been removed in several years and is all crusted tight; where can I grab/pry without damaging it or the gasket?
Posted on Mar 14, 2011
  • D-Zyne Mar 14, 2011
    Ooops- this was supposed to be a question, not a solution.
    Sorry, I'm new here...
  • 515 Answers
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Posted on Jul 17, 2008
My Gaggia Titanium has an ventilate problem when it is stil cold. After starting up, autotest and running pump, it appears whit message ventilate. It takes a long time steaming or hot water after the
The ventilate sign appears as an error message to tell operator that the flow of water is reduced. I can tell that the machine has not been descaled or was descaled using unscrupulous products that are labeled as descaler but they are not.
Because the sign disappears at this time after flushing water through the steam pipe, the flow restores the sensing that water is flowing normal. This "apparent restoration" of water flow is without any back pressure. The espresso function is restored for limited use.
This error code if not corrected immediately, it will not disappear and not allow any function even after flushing water manually.
The flow meter registers the quantitative flow of water as programmed for espresso.
Please descale the machine as soon as possible. before the 'Ventilate' error message stops all functions.
This is a well designed machine. Needs more attention to maintenance.
You may use the link to order our Best descaler.
Services Unlimited Inc Parts Guru
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 19, 2014 | Gaggia Titanium Espresso Machine
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Is vinegar ok to descale a gaggia classic?
1:2 solution vinegar to water should do the trick; rinse thoroughly!
May 12, 2010 | Gaggia Classic Espresso Machine
Gaggia Evolution is overheating
Check the thermostat on the side of the boiler, that might be damaged.
Apr 11, 2010 | Gaggia Evolution Espresso Machine
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
I have a Gaggia Evolution expresso maker about 8 years old. When button is pressed to start motor it just hums and no hot water comes out. The motor only runs if I open the steam outlet
Try this, under the grouphead, there is a screw and screen, remove those, and check screen to see if it is clogged, when screen is removed press button to brew, if water flows freely then problem is at the screen, if no water flows, then it is on the inside of the machine. You will have to run a descale cycle to clear out machine. Check the folling pic for the screen location.2722dbe.jpg
Jun 27, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Classic - water not flowing
Remove the screw and shower in the group, then press the brew button, if water flows then clean shower. I will send instructions for descale and backflush. Cut time for backflush by half.
Dec 09, 2008 | Gaggia Achille lever operated espresso...
Low water flow from gaggia evolution only 6 months old, have tried descaling, no obvious scale found in machine. pump starts but goes quiet, very feeble flow of water.
I have now solved this problem. The lack of flow associated with the pump working but running quietly is caused by the Group Head being blocked with limescale. Normal descaling cannot remove it because it cannot penetrate the Group Head.
Removing the Group Bell can be achieved using a collection of screws (see photo) and works no matter how stubborn the thing: levering it with a screwdriver in my case was impossible as it was so well glued on. 6d47425.jpg
I figure that the advice to replace the rubber seal once per year is a good one because it forces you to remove the Group Bell and clean it out.
Apr 29, 2008 | Gaggia Baby Espresso Machine
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
429 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
