Question about Microsoft Xbox 360 Console
No signal well, one time iI was on my xbox's 360 menu and I went to the settings and on the t.v. fit thing I axadently switched it to somrthing else and know when I turn it on I can here the xbox but I cant see it on my t.v. why?
  • Colleen Broome
    Colleen Broome Mar 06, 2008
    I just got a Viewsonic hdtv. My Xbox 360 works fine using the AV cables, but when I try to use the components for HDTV it says no signal. The TV is also being used for my computer monitor, which I'm running a DVI/HDMI cable - it works fine. All connections work fine except the HD component connection between the xbox and tv. I've tried all things - checked my connections, switched from TV to HDTV on the xbox plug, checked my HDTV settings (it is set to 480p). Actually the xbox does not appear to let me change those settings because it says I've got the xbox set to "TV", but then I can't set the plug to HDTV and then SEE anything on the screen to adjust settings. You know what I mean? I don't think this is an xbox cable problem cause I switched out my cable/brick with a friend's and the same thing happened. I've tried this with and without a game in the drive, turning tv off, xbox off, on, all cominations. Any ideas?? I can use the AV non-HDTV connection like I've always used, but I bought this with the intention of being able to use my xbox with HD quality. Thanks!!
  • Anonymous Jun 18, 2008
    PLUG THE HD CABLES INTO THE PROPER SPOT, SET AV CABLES TO HD, STILL NO PICTURE. WHEN I SWITCH AV CABLES TO REGULAR TV, I GET PICTURE AND SOUND BUT NOT DISPLAYED IN HD.THIS IS FOR AN XBOX360 AND A TV THAT SUPPORTS FULL 1080P HD.
Thanks for the help. After trying all the things mentioned - switching to HDTV, TV settings, standing on my head, etc.... it turned out to be that my cable was - after all - no good. I got yet another new cable and it has worked perfectly. I guess my friend's HD cable was no good too. Thanks for the input. I have learned alot from it, and hopefully I can help someone else when they have a similar problem.
Posted on Mar 27, 2008
Hey i've got the exact same problem..any solutions yet?
  • 25 Answers
Theres a switch on the AV cable right where it plugs in. Pull the cable out and switching it from HDTV to TV.
Posted on Feb 24, 2008
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
SD TECH
Sep 23, 2011 | RCA F25254GY 25" TV
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
In the zumba fitness xbox360 game, the settings are not saved when the game is restarted. What I am missing? Thanks Nancy
There is an option to save the setting on the main menu. Manually save the settings before you turn the game off, and then load them when you turn it on.
May 03, 2011 | Majesco Zumba Fitness (Kinect) for Xbox...
I went to turn on my xbox wireless drum kit and the light just came on for a second and then went out so i replaced the batteries, several times but it still wont come on
Well you can try this solution to get it too work. The thing with the XBOX 360 is that it has a hard time syncing with other controllers made by different companies. So try these steps first and see if they work if not you might have got a set of bad drums.
Step 1. Turn on XBOX 360 Step 2. Turn on drums (hold xbox button on drums). Step 3. Press sync button on 360 (XBOX ligh on console should start circling Step 4. Press sync button on drums [under D pad] (xbox light on drums should start circling)
If this doesn't work then you should RMA the drums to http://rockbandservice.ea.com to replace the bad ones.
Apr 23, 2011 | Activision Xbox 360 Guitar Hero II
My workout calendar went to 2005 date and I can no longer access the workout mode???
Go to your Xbox 360 Main menu. Go to system settings and select Console settings. Go to Clock, and select the right date and time!
Mar 12, 2011 | Majesco Zumba Fitness (Kinect) for Xbox...
How to change the language in Fable II.
by changing the locale in the xbox system
Jan 23, 2010 | Microsoft Fable 2 for Xbox 360
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
Xbox 360 - While setting up in menu the TV went black and msg. No Sync. Signal
First, make sure you select either TV or HDTV selector on the Audio Video Cable that came with the XBOX. Second, if you chose TV plug the Audio/Video Cable connectot that are red, white , and yellow in color to your TV. Now see if you can see the Start up on the XBOX360.
If you still dont get anything, try plugging it on another television and see if that fixes your problem.
Dec 09, 2007 | Microsoft Xbox 360 Console
Cannot sign up for xbox live
have you tried running the troubleshooter (if so, wat did it say?)
Apr 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
738 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
