Question about Mitsubishi VS-50605 50" Rear Projection Television
TV problem Voltage at pin 1 of IC951 is 1.7 vdc. Voltage at pin 4 of IC951 is 15.8 vdc. Does that tell you anything? REDCAT55
  • Mitsubishi Master
  • 8,617 Answers
Over Current Protection
Pin 1 of IC951 is also the Over Current Protect input.
The internal FET.s ground return is at pin 2 of
the IC. The voltage drop across R955 and R956
indicates the FET.s current, and is coupled through
R953 to pin 1 of the IC. The Over Current Protect
circuit is activated if the voltage at pin 1 of the IC
exceeds 1.35 volts.
Stabilization and rough regulation are provided by
feedback from pin 3 of T951 to pin 1 of the IC. Fine
regulation feedback is from a secondary supply,
through the Photo Coupler, PC951, to pin 1 of IC951.
Its possible that Diode D953 is leaky allowing the voltage to rise on pin 1 of the IC
Posted on Feb 23, 2008
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
Vs 5043 mitsubishi no picture
Dear dc_rock,
These the most common failures for this TV Model VS-5043- VZ3:
1. Check base bias Voltage of Q217, for 0 VDC (BIASED OFF) if .7 VDC (BIASED ON) check C268 (22 UFD 50 V) off C OF Q215 V-Protector on the SIGNAL PCB.
2. Vertical Beam Blanking Active, check PIN 4 of IC401 for 3 VDC. If missing check IC202 (5V REG) PART # 266P932010, on The SIGNAL PCB.
3. Check Pin 6 of IC200 for 9 VDC if low or missing check IC203 Part#
270P210010 on the SIGNAL PCB.
Thanks for using FIXYA, big IRISH.
Dec 25, 2009 | Mitsubishi Televison & Video
No turn signal or 4 way flashers on 2000 flhtcui , all other lights working
The turn signal module gets it's power from the accessory fuse. If the fuse is good, check for 12 volts at the #2 position on the turn signal module (located on the top fork bracket). On the turn signal module the #1 wiring pin position is ground and the #2 wiring pin position is 12 volts dc. If there is no voltage using those two pins, check for resistance between pin #1 and engine ground. If resistance is greater than 1 ohm you have a broken or poor ground wire. If resistance is less than 1 ohm check for 12 vdc on both sides of the accessory fuse. If you have 12 vdc to only one side, replace the fuse. If you have 12 vdc to both sides of the fuse you have a broken wire between the accessory fuse and the turn signal module. If you do not have 12 vdc to the accessory fuse you have a broken wire from the ignition switch and the fuse block.
Nov 16, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
Tv does not turn on. Makes ticking clock sound ?
The blinking light means the controller QA01 in the AV_TERM system board is booting and driving the TIMER/REC RED LED light accordingly. This failure mode is true for many conditions, not exclusively for the main PS board PE0071. It could be caused by many things, LOW B, SEINE, AV_TERM, LCD, PROTECT, etc.
Specifically for PE0071+12VDC circuit failure, which is the most common , listen for the LINE relays SR80, SR81 coming online.(ticking clock sound) If several (3) or more clicks are present when applying power to the TV set then suspect the +12, 20, +32 VDC inverter is faulty.
As a quick check, you can disconnect P807B. If the relays cycle every 1-2 seconds then is most definitely the +12VDC inverter. Check for voltage level at optocoupler Q881 pin 4 and this should not be cycling. This point is the VCC for the oscillator. Repair or replace board 75002913 as necessary.
TROUBLESHOOTING: (this is my own, not the OEM !, try at your own risk!)
  1. Check for LINE1 input voltage level at inverter on sheet [4].
  2. Check for LINE2 input voltage level at inverter on sheet [3].
  3. Check for STBY +5VDC & +25 VDC ( observe correct GND REF) page [4]of PE0071 POWER
  4. Check for +22 VDC out of regulator on page [3] out of Q822 Emitter
  5. Check P809B connector for :
  • P809B (12) POWER = 3.00 VDC (+/-0.2)
  • P809B (11) POWER_SIG = 0.00 VDC (HIGH to Power on TV)
  • P809B (10) PROTECT = 0.00 VDC
  • P809B (9) ACDETECT = 3.00 VDC (+/-0.2)
  1. Check for PFC_OUT = 368-371 VDC
  2. Check for +12, +20 & +32 VDC inverter page [5] of schematic manual.
For +12 VDC Inverter, suspect components:
Q880 STR-W6765 PSR (works really hot!!)
C888-C890
D884A and related switching circuit components.
Good luck,
mrwindex
Mar 12, 2009 | Toshiba 42HL196 42 in. LCD HDTV
TV problem
Check the diodes and regulators out of circuit that feed the IC especially pin 1 and pin 4
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
Let me go over the schematics and I will post what i can find that maypossibly keep taking out the IC
Tv problem
Check the connections on your front control panel PCB to see if they are all secure then trace them back to where the plug into the chassis and check the connection there as well
Mar 01, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
1) Unplug the AC cord.
2) Connect a 100 Ohm resistor (R) between
pins 4 and 5 of the IC951. This discharges C960
that may still be charged if the Over Voltage
Protect circuit was activated.
3) Remove the 100 Ohm resistor and apply
power to the set.
If the problem still exists, the IC is probably defective.
Feb 24, 2008 | Mitsubishi VS-50605 50" Rear Projection...
DEAD TV
Look for 2 resistors off of pin 2 of IC951 R955 & 956 they are hooked in parralell and the tail end of those resistors are grounded.
Feb 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
