No Power of a Compaq Presario Computer
Power supply is Bestec with 250W Max output, green light on the back flashes when plugged into the motherboard but is solid when mother board plug is removed. 12 Volt is not to problem. System will not power up, tried the power source on another system no power still. Mother board has been replaced. Tried other power supplies and still nothing happens. Any suggestions?
  • 50 Answers
Make sure that the power button is conected to the right prongs on the mother board. On the writing next to the prongs it should say power.
Posted on Feb 24, 2008
Power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer to clean and now wont turn on..No fan no nothing..Just a green...
If you didn't accidentally unplug the four pin connector near the CPU, you need to replace the power supply. This is actually a fairly common occurrence with the cheap ATX power supplies being tossed into systems these days.
Jun 15, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
I purchased a 250W Bestec Power Supply. When I plugged it in to the motherboard the light on the power supply just blinks and the computer does not turn on. I have another power supply that is the same...
did you check the switch on the back of the power supply? and is it under rated for your computer? 250 watts is much lower than what most computers use now days. the avg is 450 watt.
Jan 29, 2011 | Bestec (ATX-250-12E) 250-Watt Power Supply
MY COMPUTERS front and back green light is flashing green
you can remove your side cover,and unplug everything from your power supply. then if you plug in your computer and the light still flashes it's your power supply. If not it's something that it is powering. Most likely it's your motherboard. I had this happen to me when there was a power surge/ outage and my computer wasn't even on.
Aug 06, 2010 | Compaq Presario sr1111nx 2.53GHz Celeron...
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Motherboard taken out by eMachines Bestec power supply
I have not identified the specific components on the motherboard that blow, but I can tell you the defect in the Bestec supply. The +5 VSB, which is the voltage that is on at all times, loses regulation and climbs to 8-11 volts. I believe this "higher than the required" +5V takes out the components on the motherboard involved with the computer/power supply "turn-on" circuitry. The "on" button on the eMachines front panel no longer turns the motherboard on because the "kept alive when the main power is off circuits" - which allow the on/off button to do its job of turning on the machine - no longer work.
Test your Bestec power supply by plugging it in the wall socket and have it not connected to anything. Read the voltage between the purple wire and any black wire. If you see +5.0V, then this wasn't your problem. If, like it did on mine, is closer to between 8, and 11 V, this is what took out the motherboard.
Jan 06, 2008 | Intel D845GVSR Motherboard
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Jan 02, 2007 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
Computers & Internet Logo
343 people viewed this question
Alun Cox
David Payne
David Payne
